embeddedsys
Qt for raspberry pi
Wed Nov 07, 2012 7:33 pm
My goal is to install joyppad to keyboard support for universal usage. app is QJoyPad
http://qjoypad.sourceforge.net/
this app needs qt library to work so tried to install qt:
Err http://mirrordirector.raspbian.org/raspbian/ wheezy/main libcupsimage2 armhf 1.5.3-1
  404  Not Found
Failed to fetch http://mirrordirector.raspbian.org/raspbian/pool/main/c/cups/libcupsimage2_1.5.3-1_armhf.deb  404  Not Found
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
pi@raspberrypi:~$ sudo apt-get install qt-sdk --fix-missing
Reading package lists... Done
Building dependency tree
The following extra packages will be installed:
  cmake cmake-data emacsen-common fonts-droid ghostscript git git-core git-man
  gsfonts imagemagick imagemagick-common libapr1 libaprutil1 libaudio2
  libcupsimage2 libcurl3-gnutls libdjvulibre-text libdjvulibre21 liberror-perl
  libexiv2-12 libgl1-mesa-dev libgl1-mesa-glx libglapi-mesa libglu1-mesa
  libglu1-mesa-dev libgs9 libgs9-common libijs-0.35 libilmbase6 liblcms1
  liblensfun-data liblensfun0 liblqr-1-0 libmagickcore5 libmagickcore5-extra
  libmagickwand5 libmng1 libmysqlclient16 libneon27-gnutls libnetpbm10
  libopenexr6 libpaper-utils libpaper1 libphonon-dev libphonon4
  libpulse-mainloop-glib0 libpulse0 libqt4-dbus libqt4-declarative
  libqt4-declarative-gestures libqt4-declarative-particles libqt4-designer
  libqt4-dev libqt4-dev-bin libqt4-help libqt4-network libqt4-opengl
  libqt4-opengl-dev libqt4-qt3support libqt4-script libqt4-scripttools
  libqt4-sql libqt4-sql-mysql libqt4-sql-sqlite libqt4-svg libqt4-test
  libqt4-xml libqt4-xmlpatterns libqtcore4 libqtgui4 libqtwebkit-dev
  libqtwebkit4 libserf1 libsvn1 libwmf0.2-7 libxmlrpc-core-c3 mesa-common-dev
  mysql-common netpbm phonon-backend-null poppler-data qdbus qt4-demos
  qt4-designer qt4-dev-tools qt4-doc qt4-doc-html qt4-linguist-tools qt4-qmake
  qt4-qmlviewer qtcreator qtcreator-doc rsync subversion ufraw-batch
Suggested packages:
  ghostscript-cups ghostscript-x hpijs git-daemon-run git-daemon-sysvinit
  git-doc git-el git-arch git-cvs git-svn git-email git-gui gitk gitweb
  imagemagick-doc autotrace cups-bsd lpr lprng enscript ffmpeg gimp gnuplot
  grads hp2xx html2ps libwmf-bin mplayer povray radiance sane-utils
  texlive-base-bin transfig nas exiv2 liblcms-utils pulseaudio
  libqt4-declarative-folderlistmodel libqt4-declarative-shaders firebird-dev
  libmysqlclient-dev libpq-dev libsqlite0-dev unixodbc-dev qt4-qtconfig
  poppler-utils fonts-japanese-mincho fonts-ipafont-mincho
  fonts-japanese-gothic fonts-ipafont-gothic fonts-arphic-ukai
  fonts-arphic-uming fonts-unfonts-core libqt4-dbg libqt4-webkit-dbg
  libqt4-xmlpatterns-dbg qt-assistant-compat kdelibs5-data subversion-tools
  db5.1-util ufraw
Recommended packages:
  libgl1-mesa-dri
The following NEW packages will be installed:
  libexiv2-12 libgl1-mesa-dev libglu1-mesa libglu1-mesa-dev libgs9
  libgs9-common libijs-0.35 libilmbase6 liblcms1 liblensfun-data liblensfun0
  liblqr-1-0 libmagickcore5 libmagickcore5-extra libmagickwand5 libmng1
  libmysqlclient16 libneon27-gnutls libnetpbm10 libopenexr6 libpaper-utils
  libpaper1 libphonon-dev libphonon4 libpulse-mainloop-glib0 libqt4-dbus
  libqt4-declarative libqt4-declarative-gestures libqt4-declarative-particles
  libqt4-designer libqt4-dev libqt4-dev-bin libqt4-help libqt4-network
  libqt4-opengl libqt4-opengl-dev libqt4-qt3support libqt4-script
  libqt4-scripttools libqt4-sql libqt4-sql-mysql libqt4-sql-sqlite libqt4-svg
  libqt4-test libqt4-xml libqt4-xmlpatterns libqtcore4 libqtgui4
  libqtwebkit-dev libqtwebkit4 libserf1 libsvn1 libwmf0.2-7 libxmlrpc-core-c3
  mesa-common-dev mysql-common netpbm phonon-backend-null poppler-data qdbus
  qt-sdk qt4-demos qt4-designer qt4-dev-tools qt4-doc qt4-doc-html
  qt4-linguist-tools qt4-qmake qt4-qmlviewer qtcreator qtcreator-doc rsync
The following packages will be upgraded:
  libgl1-mesa-glx libglapi-mesa libpulse0
3 upgraded, 93 newly installed, 0 to remove and 145 not upgraded.
Need to get 128 kB/261 MB of archives.
After this operation, 607 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
  404  Not Found
Unable to correct missing packages.
E: Aborting install.
so what next? I only used a little bit of ubuntu before
srwalker101
Re: Qt for raspberry pi
Fri Dec 21, 2012 2:22 pm
Have you made sure you've run
sudo apt-get update
before trying to install?
I've found that a fresh install on my Pi requires this updating of the repositories, so might be similar for you.
