robins250
Auto Exposure Issues with Creative Live! Cam Sync HD
Mon Sep 24, 2018 2:30 am
I learned something I figured others might find useful.
I ran into an issue were the Creative Camera would pulse, flash, cycle with bright white and then return back to normal, specifically if pointed at a light or window, but sometimes just when the room is bright. It was driving me nuts and took me weeks to solve the problem. I had to learn that the driver for the cameras is called V4l2 and through trial and error I figured out how to muck with the driver settings; which can be done in real time.
First I learned I can see the current V4l2 settings for my cameras with the following command:
v4l2-ctl -d /dev/videoX -l      #where videoX is the identifier for each camera, typically video0, video1 ect.
From here you can then set the driver to stop using auto exposure with:
v4l2-ctl -d /dev/videoX --set-ctrl=exposure_auto=1
I tested this while motion was running a stream and found it stopped the auto exposure issues. This was specifically for the Creative Live! Cam Sync HD 720P Webcam.
I was wondering if anyone knew if/how I could get motion to configure the exposure_auto for the webcam through the config. I tried adding exposure_auto 1, but that didn't work.
I need more testing, but it seems the configured values are kept even when a reboot or shutdown is triggered. Otherwise a crontab could be used to set these once a day, incase of power failure.
Pangu69
Re: Auto Exposure Issues with Creative Live! Cam Sync HD
Fri Jul 12, 2019 10:16 pm
I just created this account to say thank you.
Also
sudo v4l2-ctl -d /dev/video0 -L
shows more details about the config
The "auto" exposure on Creative Live! Cam Sync HD is a joke, it doesn't work at all.
6by9
Sat Jul 13, 2019 7:31 am
Also
You don't need the sudo as long as you are in the video group (normally the case), nor the "-d /dev/video0" as that is the default.
