The fallback works for me.
But does anybody knows if the RPI should get an IP address from the DHCP server when it comes back online? That part doesn't seem to work for me....
#!/bin/bash
UPSTREAM=""
function get_upstream() {
# Look for a default gateway
UPSTREAM=$(ip r | grep default | cut -d ' ' -f 3)
function reach_upstream() {
# exit code 0 = reachable, 1 = unreachable
return $(ping -q -w 1 -c 1 ${UPSTREAM} > /dev/null)
NIC=""
function reach_dhcp_server() {
# Find nics by ifconfig
nics=($(ifconfig | egrep -ow 'eth[0-9]{1,2}'))
for nic in ${nics}; do
# If a DHCP server is found, set it on $NIC and break
reach_dhcp_server_on_interface ${nic} && { NIC=${nic}; return 0; }
done;
function reach_dhcp_server_on_interface() {
local interface=${1}
# nmap command to find a DHCP server on an interface
local nmap_command="sudo nmap --script broadcast-dhcp-discover -e ${interface}"
# exit code 0 = router, 1 = no router
return $(${nmap_command} 2>/dev/null | grep Router | egrep -wo '[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}' > /dev/null)
function reset_ip() {
# Tell dhcpcd to rebind $NIC
dhcpcd -n ${NIC}
# Detect if there's an upstream and if it's reachable. If so, exit
get_upstream
if ! [ -z ${UPSTREAM} ]; then
echo "Trying to ping ${UPSTREAM}"; reach_upstream && echo "Ping succeeded, keeping IP"; exit 0 || echo "Ping failed..."
fi
# Check for a DHCP server. If not found, exit
echo "No upstream, checking for DHCP server"; reach_dhcp_server || { echo "DHCP server not found"; exit 0; }
# Lets go
echo "DHCP server found, resetting IP"; reset_ip
[Unit]
Description=Restarts dhcpcd if there's no internet but a DHCP server is found
[Service]
Type=oneshot
ExecStart=/sbin/dhcp-recheck.sh
[Unit]
Description=Run dhcp-recheck every 2 minutes
[Timer]
OnCalendar=*:0/2
#When missed a cycle, do not rechedule on reboot
Persistent=False
[Install]
WantedBy=timers.target
systemctl enable dhcp-recheck.timer && systemctl start dhcp-recheck.timer
profile static_eth
static ip_address=192.168.0.1
dhcp
# Try DHCP first, else fall back to static
interface eth0
fallback static_eth
# This enables us to plug in an additional ethernet adapter;
# one of them will be accessible for internet, the other one for a direct connection
interface eth1
fallback static_eth
