LTolledo
Re: [Guide][Testing] Kodi 18.0 Leia beta versions for Raspbian Stretch!
Thu Feb 21, 2019 12:43 pm
Well I've been using the latest Kodi 18 for the past weeks
One thing I noticed, it takes longer for return to video file selection after finishing any video I watched (20 to 40 seconds delay), unlike when it was still 17.6 (usually takes 10 secs or less).
Kodi player on RPi3B+
files are accessed from RPi3B NAS over GbE LAN.
no other hardware changes
just Kodi upgrade from 17.6 to 18.0 after running apt update and apt upgrade
is this a known problem? any solution in the horizon?
if none, is there a procedure to revert back to 17.6?
Some people be like:
Rascas
Thu Feb 21, 2019 1:01 pm
Never noticed any delay when video finishes, it goes instantly (or it 1 or 2 seconds, never noticed) to the library or folder. In Kodi 18 and older versions.
Which protocol are you using ? SMB is known to have some issues in Kodi 18, although I don't have any problem.
mcarty
Thu Feb 21, 2019 1:30 pm
I dont have delays neither.
DarrenHill
Thu Feb 21, 2019 2:55 pm
Also where is your Kodi database stored, locally or remotely?
That kind of delay sounds to me like some issue with the database, either some corruption in it or some network issues in trying to write and update it after watching something (changing the watched state stored etc).
HiassofT
Thu Feb 21, 2019 7:14 pm
I didn't experience this issue myself yet but it sounds like this kodi change https://github.com/xbmc/xbmc/pull/15459 - which is included in Kodi 18.1 - should fix it.
so long,
Hias
LTolledo
Thu Feb 21, 2019 10:06 pm
Did an update and upgrade just now but did not see the Kodi in the list.
Confirming my Kodi is still 18.0 after the upgrade.
for the other questions:
1. library is stored locally to this RPi3B+
2. smbv1 is maximum protocol set
no improvement after setting the maximum protocol to smbv3 and the minimum protocol to smbv1
and it does seem that Kodi is accessing the network after finishing the video (watched the LED activity on the GbE switch).
rewatching a previously marked watched video, still the delay persist.
Rascas
Thu Feb 21, 2019 10:36 pm
Kodi 18.0 is still the latest version available on Raspbian. I know that the 18.1 final commit is already merged, but since there wasn't an announcement on the oficial page, I wasn't in a hurry to update it. I will update it this weekend and then post a reply here. But I am not sure if that will fix it for you. My advice is to use a SMB mount on the OS level, or better yet use NFS.
LTolledo
Fri Feb 22, 2019 1:26 am
Despite the "bug" I still prefer Kodi as video player over VLC.....
....will wait for the update this weekend and hope it "exterminates" the bug....
an announcement of its availability will be much appreciated.
Keep up the good work guys!
Rascas
Fri Feb 22, 2019 6:10 pm
Since Kodi 18 is now stable and available on the RPi Foundation repo, I ask for people with questions and/or problems to use the following post to keep things easier to track:
https://www.raspberrypi.org/forums/view ... 6&t=192499
Regards
mahjongg
Sat Feb 23, 2019 2:23 am
this thread is now obsolete, so locking....
Return to “Media centres”
