gennargiu
raspbian stretch and second enviroment e17
Tue Sep 18, 2018 8:35 am
hi i have a problem with my raspberry pi3 and start second enviroment e17 . I have a installed from repository official raspberry (raspbian stretch) this package from synaptic,but when i reboot it start only lxde of raspbian stretch. can you help me for start e17 on my rpi 3 ? many thanks and best regards.
gennaro
Raspberry Pi3 Starter Kit
cjan
Re: raspbian stretch and second enviroment e17
Tue Sep 18, 2018 10:38 am
log out and choice from lightdm?
gennargiu
Tue Sep 18, 2018 1:32 pm
hello although lightdm is installed when raspbian stretch reboot there is no indication to change enviroment. How to have this possibility? thank you
ksharindam
Tue Sep 18, 2018 1:48 pm
To boot to e17 directly you have to select e17 as default x-session-manager. To do this run this command
sudo update-alternatives --config x-session-manager
and select e17.
Then reboot.
gennargiu
Tue Sep 18, 2018 2:43 pm
and select e17.
Then reboot.
hi many thanks for your help me, i have a insert your code in the terminal raspbian stretch,but e17 don't wiev in list. e17 is installed from official package raspbian stretch from synaptic program
ksharindam
Tue Sep 18, 2018 4:42 pm
It seems installing e17 package only provides the window manager, and not the session or desktop. So you can not start enlightenment session.
gennargiu
Tue Sep 18, 2018 7:56 pm
with your help me and insert code terminal i have a installed a new enviroment xfce 4. It's work perfect at reboot raspbian stretch and is view in list enviroment in the terminal ;)
gennaro
Return to “Raspberry Pi OS”
