diresu
Chinese input method? [solved]
Sun Sep 16, 2018 9:58 pm
I would like to be able to write in Chinese on my Raspberry Pi.
Is there anybody who could explain me how to install a Chinese input method and make it work?
My own attempts failed all...
Thanks,
Dietrich
allfox
Re: Chinese input method?
Mon Sep 17, 2018 9:28 am
I use a headless setup, so not sure about the exact steps.
But essentially, you need a Chinese font, an input method framework(daemon), and an actual input method.
Raspbian is Debian mostly, so it might worth trying https://wiki.debian.org/gnome-chinese-input
EDIT: I just remember that Raspbian is not GNOME!
Well, I don't know how to make it work. Sorry.
diresu
Mon Oct 01, 2018 7:43 pm
Hi allfox!
Thank you anyway :)
I finally managed to make Chinese and Japanese Input work as follows - I hope this is helpful for others in need to write in Chinese or Japanese on the Raspberry Pi.
Cheers,
Dietrich
=== Chinese Input ===
1. Add Chinese locale (in my case 'zh_CN.UTF-8') via:
sudo dpkg-reconfigure locales
Select and install: zh_CN.UTF-8 UTF-8
2. Install Chinese fonts:
sudo apt-get install \
fonts-arphic-bkai00mp \
fonts-arphic-bsmi00lp \
fonts-arphic-gbsn00lp \
fonts-arphic-gkai00mp \
xfonts-intl-chinese \
xfonts-intl-chinese-big
3. Install fcitx and fcitx-libpinyin:
fcitx \
fcitx-libpinyin
4. Open the Input Method Configuration
Either from the command line:
sudo im-config
or via the main menu:
Raspberry Pi Menu > Preferences > Input Method
- First screen:
Current confituration for the input method...
click [OK]
- Second screen:
Do you explicetly select the user configuration?
click [YES]
- Third screen:
Select: (*) fcitx activate Flexible Input Method Framework (fcitx) @
click [OK]
5. Reboot
There should be a small keyboard icon on the right side of the panel.
- right click on the keyboard icon
and choose either 'Configure current input method' or 'Configure'
- click the '+' symbol on the lower left of the window popping up
- Uncheck 'Only Show Current Language' in the window popping up
- Enter the term 'pinyin' in the search field
- select the field 'Pinyin (LibPinyin)' and click [OK]
- close the window
Now it should be possible to select the input method
'Pinyin (LibPinyin)' from the keyboard icon in the panel:
- hover over 'input method'
- and select 'Pinyin (LibPinyin)'
The input method now can be toggled between English and Chinese using
the key combination 'ctrl-space'...
=== Japanese Input ===
1. Add Japanese locale (in my case 'ja_JP.UTF-8') via:
Select and install: ja_JP.UTF-8 UTF-8
2. Install Japanese fonts:
xfonts-intl-japanese \
xfonts-intl-japanese-big \
fonts-takao
3. Install fcitx and mozc:
fcitx \
fcitx-mozc
sudo im-config
- First screen:
click [OK]
- Second screen:
click [YES]
- Third screen:
click [OK]
5. Reboot
'Mozc' from the keyboard icon in the panel:
- hover over 'Input Method'
- and select 'Mozc'
The input method now can be toggled between English and Japanese using
GuruMeditation
Re: Chinese input method? [solved]
Sun Sep 15, 2019 11:58 am
On Raspberry Pi 4, Raspbian Buster:
E: Unable to locate package fctix-libpinyin
hilliao
Mon Feb 10, 2020 7:30 am
The fctix-libpinyin package has changed to fcitx-pinyin. To install both pinyin 拼音 and zhuyin 注音 (used in Taiwan), execute the following command:
 sudo apt-get install fcitx-pinyin fcitx-zhuyin
if you don't have im-config, install it
sudo apt install im-config
HappilyEverAfter
Mon May 18, 2020 2:05 pm
I found installing fonts unnecessary and it made Chromium display ugly as I don't like the default Chinese font used by Chromium - "AR PL KaitiM GB".
