andrea.miclausig
Real time kernel patch
Sun Sep 16, 2018 1:50 pm
Hey guys! I'm fairly new to Raspberry. I have a Pi 3 and I need to have a real time kernel. Actual version as seen from uname -r is 4.14.69-v7+. I've recompiled it as per these isntructions https://www.raspberrypi.org/documentati ... uilding.md with the only difference being that I used make menuconfig instead of make bcm2709_defconfig to have a GUI. Everything looks fine and after the reboot the kernel versione got updated to 4.14.69-V7+. Now, even if I turned on the real time option in make menuconfig, it's not RT yet. So I tried to patch it as per this link https://www.raspberrypi.org/documentati ... atching.md of course replacing the patch version with the correct one. Aaand I get the error
gzip: patch-4.14.69-rt43.patch already exists; do you wish to overwrite (y or n)? y
can't find file to patch at input line 5
Perhaps you used the wrong -p or --strip option?
The text leading up to this was:
|diff --git a/Documentation/trace/events.txt b/Documentation/trace/events.txt
|index 2cc08d4a326e..e28f7f29f2b3 100644
|--- a/Documentation/trace/events.txt
|+++ b/Documentation/trace/events.txt
Sooo... what should I do now? Itried keeping ESC pressed while rebooting to see if there were other options like in Ubuntu, but nothing came up.
Can someone help me? Thanks.
DarkPlatinum
Re: Real time kernel patch
Sun Sep 16, 2018 2:46 pm
Do you mean something like conky? https://html.dynu.net/index.php/installing-conky-linux/ Not really sure what you mean by real time kernel.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): Https://Html.dynu.net
andrea.miclausig
Sun Sep 16, 2018 2:48 pm
Nope, I don't mean anything like Conley. I'm talking about a real time kernel for real time operation. In my case, I'm working with the powerlink protocol, which needs a real time kernel.
DirkS
Sun Sep 16, 2018 2:53 pm
I wouldn't worry too much about it. But if you're interested search for terms such as 'RT kernel', realtime kernel' also combined with 'raspberry pi'
e.g. https://medium.com/@patdhlk/realtime-linux-e97628b51d5d
https://wiki.archlinux.org/index.php/Realtime_kernel
https://www.raspberrypi.org/forums/view ... p?t=206747
DarkPlatinum
Sun Sep 16, 2018 2:56 pm
Thanks for this information, learned something new today! :)
andrea.miclausig
Sun Sep 16, 2018 3:19 pm
Yes, that's what I mean. Thing is I get the attached error when trying to apply the patch.
Return to “Raspbian”
