RPIWnivarna
Stretch gui vs stretch lite python3
Sun Sep 16, 2018 6:17 am
Hello world,
I have tried to search for this answer, apologies in advance if I missed it, or if I have posted this on the wrong forum
Youtuber Tinkernut pointed out this python3 script (I will share at the bottom including my systemd setup) which I have used extensively in my rpi zero projects.
It takes the rpi camera module stream and serves it up in a browser window on your network at ip addr:8000.
Now the python3 script works without a hitch with 2018-04-18-raspbian-stretch.img, but not 2018-06-27-raspbian-stretch-lite.img, which I would prefer to use for a simplified base system.
Can anyone give me some advice or pointers how I can get the python3 modules default on 2018-04-18-raspbian-stretch.img onto my 2018-06-27-raspbian-stretch-lite.img?
Below is the python script called spi_cam.py and systemd setup I follow
cd ~
sudo nano spi_cam.py
and paste in below: # Web streaming example
# Source code from the official PiCamera package
# http://picamera.readthedocs.io/en/lates ... -streaming
import io
import picamera
import logging
import socketserver
from threading import Condition
from http import server
PAGE="""\
<html>
<head>
</head>
<body>
<center><img src="stream.mjpg" width="640" height="480"></center>
</body>
</html>
class StreamingOutput(object):
def __init__(self):
self.frame = None
self.buffer = io.BytesIO()
self.condition = Condition()
def write(self, buf):
if buf.startswith(b'\xff\xd8'):
# New frame, copy the existing buffer's content and notify all
# clients it's available
self.buffer.truncate()
with self.condition:
self.frame = self.buffer.getvalue()
self.condition.notify_all()
self.buffer.seek(0)
return self.buffer.write(buf)
class StreamingHandler(server.BaseHTTPRequestHandler):
def do_GET(self):
if self.path == '/':
self.send_response(301)
self.send_header('Location', '/index.html')
self.end_headers()
elif self.path == '/index.html':
content = PAGE.encode('utf-8')
self.send_response(200)
self.send_header('Content-Type', 'text/html')
self.send_header('Content-Length', len(content))
self.end_headers()
self.wfile.write(content)
elif self.path == '/stream.mjpg':
self.send_header('Age', 0)
self.send_header('Cache-Control', 'no-cache, private')
self.send_header('Pragma', 'no-cache')
self.send_header('Content-Type', 'multipart/x-mixed-replace; boundary=FRAME')
self.end_headers()
try:
while True:
with output.condition:
output.condition.wait()
frame = output.frame
self.wfile.write(b'--FRAME\r\n')
self.send_header('Content-Type', 'image/jpeg')
self.send_header('Content-Length', len(frame))
self.end_headers()
self.wfile.write(frame)
self.wfile.write(b'\r\n')
except Exception as e:
logging.warning(
'Removed streaming client %s: %s',
self.client_address, str(e))
else:
self.send_error(404)
self.end_headers()
class StreamingServer(socketserver.ThreadingMixIn, server.HTTPServer):
allow_reuse_address = True
daemon_threads = True
with picamera.PiCamera(resolution='640x480', framerate=24) as camera:
output = StreamingOutput()
#Uncomment the next line to change your Pi's Camera rotation (in degrees)
#camera.rotation = 90
camera.start_recording(output, format='mjpeg')
try:
address = ('', 8000)
server = StreamingServer(address, StreamingHandler)
server.serve_forever()
finally:
camera.stop_recording()
##############################Systemd setup
sudo nano /lib/systemd/system/stream.service
[Unit]
Description=My Script Service
After=multi-user.target
[Service]
Type=idle
ExecStart=/usr/bin/python3 /home/pi/spi_cam.py &> /tmp/camoutput.txt &
[Install]
WantedBy=multi-user.target
sudo chmod 644 /lib/systemd/system/stream.service
sudo systemctl daemon-reload
sudo systemctl enable stream.service
sudo reboot
And it should [email protected] pi ip addr:8000 in your browser address bar on your wifi network
bensimmo
Re: Stretch gui vs stretch lite python3
Sun Sep 16, 2018 7:55 am
You may want to format your post with code tags and things, check he bbcode link (under the smilies) and/or use the formatting toolbar.
Return to “Camera board”
