Corsasri
Get a python game running without desktop.
Sat Sep 15, 2018 8:58 am
I have downloaded a file from github that works via desktop. How do i go about getting this to run without it loading the desktop version by using a lite version.
This is what i want to get working.
https://github.com/martinr1000/AliensMotionTracker
DirkS
Re: Get a python game running without desktop.
Sat Sep 15, 2018 11:02 am
I had a quick look and it seems to use pygame, so it should be sufficient to install that.
The program would run in full-screen instead of in a window.
The installation instructions are actually a bit dodgy.
It's assumed you're using a pitft screen (GPIO connected small screen)
And the autostart bit assumes you're using the desktop.
So there could be a few problems to solve before you get it working.
Corsasri
Sun Sep 16, 2018 12:31 pm
Thanks for the reply. No i`m not using an attached tft display. Using stretch lite i installed pygame. But how do i go about getting it to work ? i think i need to write a script ?
B.Goode
Sun Sep 16, 2018 12:42 pm
Yes. Isn't that what the GitHub repository you cited contains?
Corsasri
Sun Sep 16, 2018 1:07 pm
The game runs in the desktop version of raspian. but i want to know how to get it to run using stretch lite. I have no idea there to start.
B.Goode
Sun Sep 16, 2018 3:02 pm
How do you start it if you run it from the Raspbian GUI Desktop?
DirkS
Sun Sep 16, 2018 3:09 pm
The instructions say to autostart it in the usual way.
I had a better look at the instructions and it's not straightforward to get it running on Stretch Lite with a HDMI screen.
(original instructions are for Jessie Desktop on a PiTFT and they will certainly not work on Stretch)
Maybe OP could ask the creator by creating an issue on Github: https://github.com/martinr1000/AliensMo ... ker/issues
Return to “Python”
