sagarpi
Bluetooth/WiFi conflict
Wed Sep 12, 2018 7:12 pm
I have turned my raspberry pi into a bluetooth audio receiver following this thread.Got it working after awhile, only problem is that the audio skips/stutters every 5 seconds. I found out that its caused by the WiFi and Bluetooth running at the same time. When I manually switch off WiFi whenever I play music it the audio plays fluently, however its just tiring having to do that every time and then having to power-reboot my pi to get WiFi up again.
A simple solution for me would be to listen to the bluetooth interface and having a script run that disables WiFi when a device connects via bluetooth with my pi and enables WiFi again once the device disconnects. Its a little ironic that I call this solution simple since I actually have no idea how to go about it. I am currently working off the thread below to code my own program. Douglas6 suggests monitoring the the dbus system for bluez messages, and reacting to them. However I don't have any knowledge about that stuff. Could you guys tell if i am on the right path, or maybe someone even knows a better and/or already existing solution?
    Thanks in advance :)
    Douglas6
    Re: Bluetooth/WiFi conflict
    Wed Sep 12, 2018 7:47 pm
    If you want to determine when a Bluetooth device connects or disconnects, listening to the D-Bus signals is probably your best bet.
    What model Pi are you using? I was hoping they solved the Bluetooth/WiFi issues with the 3B+.
    sagarpi
    Thu Sep 13, 2018 8:19 pm
    just checked, I am using Model B, should have considered that when i bought it, how sure are you the B+ resolves the issue? might just buy it again. From the github thread this guy says the b+ doesnt work for him, where as this guy says b+ works.
    Douglas6
    Thu Sep 13, 2018 8:29 pm
    Not at all sure, to be honest. I have not tried it on my Pi3B+ (actually, I might have, briefly, and didn't see a problem; no promises, though) . There seem to be fewer complaints on this forum, is all. A cheaper solution would be to purchase a USB Bluetooth dongle, and disable the onboard one. On the other hand, what could be the possible downsides of owning an extra Pi?
    HawaiianPi
    Fri Sep 14, 2018 2:36 am
    I have used both a Pi3B and 3B+ on my Bluetooth speakers and never got satisfactory results. I don't recall issues with music playback, but videos were always out of sync with the sound. No such problems with my Windows 10 laptop or Android phone.
    Douglas6
    Fri Sep 14, 2018 2:50 am
    I've experienced the same kind of out-of-sync with video. And not only on the Pi. My advice: don't expect video and audio synchronization ever, using Bluetooth. Just don't.
    HawaiianPi
    Fri Sep 14, 2018 4:36 am
    As I said above, it works fine with my Android phone and Win10 laptop. No audio/video sync issues with either.
    sagarpi
    Fri Sep 14, 2018 7:38 pm
    Wheres the fun it that lol. Id rather code a solution
    cheers
    Douglas6
    Fri Sep 14, 2018 7:49 pm
    More power, Bro.
    LTolledo
    Fri Sep 14, 2018 8:19 pm
    At the moment my policy on this is:
    "If you WiFi... don't Bluetooth! If you Bluetooth.... don't WiFi!"
    Some people be like:
