myotherpcisapdp11
Broken package in raspbian
Mon Sep 10, 2018 5:46 pm
Current up to date stretch (at date of this post):
o/_____________________________________
O\
aptitude install gcc-aarch64-linux-gnu
gcc-aarch64-linux-gnu{b}
0 packages upgraded, 1 newly installed, 0 to remove and 6 not upgraded.
Need to get 0 B/2,958 B of archives. After unpacking 19.5 kB will be used.
The following packages have unmet dependencies:
gcc-aarch64-linux-gnu : Depends: gcc-5-aarch64-linux-gnu (>= 5.2.1-13cross1) which is a virtual package and is not provided by any available package
The following actions will resolve these dependencies:
Keep the following packages at their current version:
1) gcc-aarch64-linux-gnu [Not Installed]
Accept this solution? [Y/n/q/?]
O\
Deliberate omission?
XXX
M
Re: Broken package in raspbian
Mon Sep 10, 2018 7:55 pm
O\
O\
XXX
M
Raspbian Jessie or stretch ?
Though a full update of the OS should be first step:
sudo apt-get update
sudo apt-get dist-upgrade
sudo reboot
RPi 4B 4GB (SSD Boot)..
DavidS
Mon Sep 10, 2018 10:04 pm
That is interesting. Raspbian is 32 bit, and it is missing an aarch64 gcc package, it does not make since that a 64 bit package would be required for anything on a 32 bit os.
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
myotherpcisapdp11
Wed Sep 12, 2018 5:10 pm
sudo apt-get update
sudo reboot
As my original post stated.
It's not a newbie error. Tried tagging it in aptitude to verify the problem? I tried on my own machines and again at a friends house. Same problem.
Cheers!
M.
myotherpcisapdp11
Wed Sep 12, 2018 5:15 pm
Raspbian is indeed 32 bit, but it should be able to cross-compile/cross assemble for other platforms. The package is in the repository to do this, but at least one dependancy (and perhaps sub-dependancies for that) are unavailable. It's probably just a bug in the build of the repo, but conceivable that Broadcom don't want people finding shortcomings in their v8 implementation and have "applied some influence" (there are possibly a few, but my tests so far indicate they should not have too much to worry about in that respect. :-)
Cheers!
M.
Return to “Raspberry Pi OS”
