hanspython
[SOLVED] pir motion detection
Mon Sep 10, 2018 8:34 am
Hi to all
Is there a possibility to make a log file from the pir now everything is on the screen but i want the output in a log file is that possible?
This i my standard:
# HC-SR501 motion sensor
# https://raspberrytips.nl/hc-sr501-beweg ... pberry-pi/
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BOARD)
PIN = 26
GPIO.setup(PIN, GPIO.IN)
print "Start sensor..."
time.sleep(2)
print "Sensor alarm geactiveerd let op!.."
while True:
if GPIO.input(PIN):
print "Let op er zijn mensen buiten de afgesproken tijd lokatie Tilburg " + (time.strftime("%H:%M:%S")) This line in a log file
time.sleep(2)
time.sleep(0.1)
Brandon92
Re: pir motion detection
Mon Sep 10, 2018 9:07 am
I found this youtube video very helpful for this question.
PhatFil
Mon Sep 10, 2018 9:11 am
if you run it from the command line you can simply redirect the output to file by appending
 >> /home/pi/logs/mylogfile.txt
to the end of the program command ie
$ ./myscript.py >> /home/pi/logs/mylogfile.txt
edit the path to the file must exist, the file will be created or if it exists be appended to.
gordon77
Mon Sep 10, 2018 9:21 am
import time
logfile = 'log2.txt'
PIN = 26
print ("Start sensor...")
time.sleep(2)
print ("Sensor alarm geactiveerd let op!..")
while True:
    if GPIO.input(PIN):
        print ("Let op er zijn mensen buiten de afgesproken tijd lokatie Tilburg " + (time.strftime("%H:%M:%S"))) #This line in a log file
        with open(logfile, "a") as file:
            file.write("Let op er zijn mensen buiten de afgesproken tijd lokatie Tilburg " + (time.strftime("%H:%M:%S"))+ "\n")
time.sleep(2)
time.sleep(0.1)
hanspython
Mon Sep 10, 2018 11:13 am
import time
PIN = 26
time.sleep(2)
while True:
    if GPIO.input(PIN):
time.sleep(2)
time.sleep(0.1)
Wonderful its working thanks
hanspython
Mon Sep 10, 2018 11:32 am
import time
PIN = 26
time.sleep(2)
while True:
    if GPIO.input(PIN):
time.sleep(2)
time.sleep(0.1)
If i interrupt the program i get this;
File "hcsr501.py", line 22, in <module>
time.sleep(0.1)
gordon77
Mon Sep 10, 2018 11:57 am
How are you interrupting?
If using ctrl&C it's simply showing where it was when you stopped it.
hanspython
Mon Sep 10, 2018 1:06 pm
Just ctrl&c
thanks for the replay.
Item ready for closed
gordon77
Mon Sep 10, 2018 1:35 pm
Just modify the title to say ' [SOLVED] pir motion detection'
Return to “Beginners”
