PelegPLT
Raspberry Pi suddenly throws FAILEDs on boot
Sat Sep 08, 2018 11:06 am
So my Pi3B was working perfectly until today, where for some reason it decided to reboot and fail.
some of them being about running MariaDB, xRDP.
but one of them was "Failed to start UpdateUTMP about System boot/shutdown." Which led to "Dependency failed for Update UTMP about System RunLevel changes.
It's getting stuck on "Started D-Bus System Message Bus" and I can't put any command in the boot screen.
There is one more thing that I missed when it boots and I couldn't find the updated boot log to find out what it is.
epoch1970
Re: Raspberry Pi suddenly throws FAILEDs on boot
Sat Sep 08, 2018 2:08 pm
Disk full? Dead SD card?
PelegPLT
Sun Sep 09, 2018 2:55 pm
Nope, I could read from the SD card on windows and no chance it's full.
DavidS
Sun Sep 09, 2018 4:16 pm
Just because you can read from the card does not mean it is still good. I have had one SD Card with BSD fail, it still reads well, though trying to write to it is hit or miss.
Save power, use fewer cycles total. Assembly Language forever :) .
PelegPLT
Sat Sep 15, 2018 12:58 pm
sorry for the late response, how do I check it's status?
Also, does the lightning bolt that appears top right has anything to do with it?
pcmanbob
Sun Sep 16, 2018 10:50 am
That would indicated you power supply is not outputting 5v, but some thing below 4.65V.
low volt situations like this can cause you pi to reboot spontaneously, which could result in SD card corruption.
What power supply are you using and how old is it ?
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
PelegPLT
Sun Sep 16, 2018 7:55 pm
That would indicated you power supply is not outputting 5v, but some thing below 4.75V.
I'm using the JBL Orange brick that comes with the speaker, but I run the Pi, a 3.5" screen and a case fan I turned into USB. But it's been going off for months already. It is capable of 5V.
pcmanbob
Sun Sep 16, 2018 8:41 pm
So you are trying to use a speaker power supply to run a pi3B a screen and a fan !
It might say 5v on it but at what current ? I would think you would need at least 2.5A to supply all that, and you power supply needs to supply 2.5A at 5V no some thing under 5V which is what it looks like your existing power supply is doing.
If you have been seeing an under-voltage alarm for months I would say you have been lucky not to corrupt your SD card, may be your power supply is now starting to fail due to it being run in an overload state for so long, and that's why your pi rebooted spontaneously .
PelegPLT
Tue Sep 25, 2018 3:58 pm
I run the fan because the screen doesn't turn off it's just black and it overheats like crazy. I can get another source of power for this fan but my question is what am I doing with the SD card? I can write to it and take stuff off it.
pcmanbob
Tue Sep 25, 2018 8:03 pm
I would say you need to consider a new power supply for your pi and the screen etc, I suggest the raspberry pi official power supply.
you still have not said what the current rating of this JBL Orange brick is supposed to be.
then you can see if you still have a problem with the SD card or if you pi will boot properly, but I would suspect you may have either SD card corruption or possibly a failed SD card which you can write to, but its pointless trying to solve the SD card problem while you are still getting under voltage warnings.
PelegPLT
Fri Sep 28, 2018 12:53 pm
I said a few posts back it supplies up to 5V. The raspberry boots fine with another SD card and the "corrupt" one can be written to and read of just fine.
epoch1970
Fri Sep 28, 2018 12:59 pm
5V at which amperage?
Return to “Raspbian”
