Fauveboy
Raspberry Pi 7inch Touchscreen Brighness
Fri Sep 07, 2018 6:09 pm
How can I change the brightness of the official raspberry pi 7 inch touchscreen?
DirkS
Re: Raspberry Pi 7inch Touchscreen Brighness
Fri Sep 07, 2018 6:14 pm
Write a value between 0 to 255 (inclusive) to /sys/class/backlight/rpi_backlight/brightness
e.g.
sudo sh -c 'echo "100" > /sys/class/backlight/rpi_backlight/brightness'
W. H. Heydt
Sun Sep 16, 2018 2:33 am
e.g.
You don't need quotes around the brightness value. The root crontab entry to dim the 7" display on my "alarm clock" is...
# Evening Dim Display
00 22 * * * echo 17 > /sys/class/backlight/rpi_backlight/brightness
DirkS
Sun Sep 16, 2018 9:15 am
I can't see any mention of crontab or startup in OP's post...
W. H. Heydt
Mon Sep 17, 2018 2:14 am
I could have stripped off the cron timing and stuck "sudo" in front of the command. it's simply an illustration that you don't need to put to value for the backlight in quotes.
DirkS
Mon Sep 17, 2018 8:47 am
By adding the irrelevant cron thing you are more likely to confuse users.
IMNSHO it would have better if you had not responded at all instead of using the cron example just to show that there is an alternative way of formatting the command.
W. H. Heydt
Tue Sep 18, 2018 3:15 am
Perhaps we should wait to see if the OP expresses any confusion before jumping to that conclusion.
