dr.sputnik
PoE HAT Fan Speed adjustment
Thu Aug 30, 2018 4:01 pm
I saw the notes in ETA for Official POE Hat for 3B+, and decided to try this on one of mine.
After editing, compiling and copying over the file to the overlays folder, the fan no longer works. Also the faint high pitch noise made by the PoE HAT during boot is absent. Copying the original overlay file back and rebooting results in it all working again.
I downloaded the code from https://github.com/raspberrypi/linux/ra ... verlay.dts and edited it as follows:
pi@dtc1:~/fan-control $ cat rpi-poe-overlay.dts
 * Overlay for the Raspberry Pi POE HAT.
/dts-v1/;
/plugin/;
        compatible = "brcm,bcm2708";
        fragment@0 {
                target-path = "/";
                __overlay__ {
                        fan0: rpi-poe-fan@0 {
                                compatible = "raspberrypi,rpi-poe-fan";
                                firmware = <&firmware>;
                                cooling-min-state = <0>;
                                cooling-max-state = <3>;
                                #cooling-cells = <2>;
                                cooling-levels = <0 50 150 255>;
                                status = "okay";
        fragment@1 {
                target = <&cpu_thermal>;
                __overlay__ {
                        trips {
                                threshold: trip-point@0 {
                                        temperature = <50000>;
                                        hysteresis = <5000>;
                                        type = "active";
                                target: trip-point@1 {
                                        temperature = <55000>;
                                        hysteresis = <2000>;
                                        type = "active";
                                cpu_hot: cpu_hot@0 {
                                        temperature = <60000>;
                                        type = "active";
                        cooling-maps {
                                map0 {
                                        trip = <&threshold>;
                                        cooling-device = <&fan0 0 1>;
                                map1 {
                                        trip = <&target>;
                                        cooling-device = <&fan0 1 2>;
                                map2 {
                                        trip = <&cpu_hot>;
                                        cooling-device = <&fan0 2 3>;
and then ran:
dtc -@ -I dts -O dtb -o rpi-poe.dtbo rpi-poe-overlay.dts
That command produces warnings:
pi@dtc1:~/fan-control $ dtc -@ -I dts -O dtb -o rpi-poe.dtbo rpi-poe-overlay.dts
rpi-poe.dtbo: Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
rpi-poe.dtbo: Warning (unit_address_vs_reg): Node /fragment@0/__overlay__/rpi-poe-fan@0 has a unit name, but no reg property
rpi-poe.dtbo: Warning (unit_address_vs_reg): Node /fragment@1 has a unit name, but no reg property
rpi-poe.dtbo: Warning (unit_address_vs_reg): Node /fragment@1/__overlay__/trips/trip-point@0 has a unit name, but no reg property
rpi-poe.dtbo: Warning (unit_address_vs_reg): Node /fragment@1/__overlay__/trips/trip-point@1 has a unit name, but no reg property
rpi-poe.dtbo: Warning (unit_address_vs_reg): Node /fragment@1/__overlay__/trips/cpu_hot@0 has a unit name, but no reg property
After copying it to the
/boot/overlays/
folder, after rebooting the PI the fan does nothing - not even when the temperature gets up above 65degC.
Additionally, after applying it, I ran dmesg -w and noticed that I'm now getting over-current warnings: I don't have any devices plugged into the PI at all; its headless and I connect over SSH.
pi@dtc1:~ $ sudo dmesg -C
pi@dtc1:~ $ dmesg -w
[   72.037711] usb 1-1-port2: over-current change
[   72.131720] usb 1-1.1-port2: over-current change
[   72.271588] usb 1-1-port3: over-current change
[   72.371592] usb 1-1.1-port3: over-current change
[   72.511585] usb 1-1-port4: over-current change
[   93.891759] usb 1-1.1-port2: over-current change
[   94.053660] usb 1-1-port2: over-current change
[   94.131606] usb 1-1.1-port3: over-current change
[   94.301594] usb 1-1-port3: over-current change
[   94.371595] usb 1-1.1-port2: over-current change
(this goes on and on and on...)
Any thoughts? Help!
Thanks!
martinrowan
Re: PoE HAT Fan Speed adjustment
Thu Aug 30, 2018 7:35 pm
On the over-current warnings, this is something being tracked in this thread: https://www.raspberrypi.org/forums/view ... 5&t=220984
Sorry due to the over-current issues, I've not experimented with altering the fan profile myself.
martinrowan
Sun Sep 02, 2018 5:29 pm
I too had the same issue with the updated overlay not working. It looks like 4 days ago there was a code change submitted (https://github.com/raspberrypi/linux/co ... c65db65959) which modified the file: rpi-poe-overlay.dts
Since the new driver that included the rest of the changes isn't released yet, it's necessary to get the older version of the file or just undo the simple change.
Change:
Back to:
compatible = "rpi-poe-fan";
Or download the older version of the file: https://raw.githubusercontent.com/raspb ... verlay.dts
Also running the command as root ensure the files are created with root owner and group as per the original file:
sudo dtc -@ -I dts -O dtb -o rpi-poe.dtbo rpi-poe-overlay.dts
Hopefully that will get your fan working once again and able to change the thresholds.
Thanks Martin
dr.sputnik
Tue Sep 04, 2018 12:24 pm
That's sorted it! Many thinks.
hansamann
Fri Oct 12, 2018 5:34 pm
If someone else feels the POE fan needs more user-controllable settings, please consider voting / starring for an issue I created =:
https://github.com/raspberrypi/linux/is ... 3Aopen+poe
TLDR: make the fan user controllable with different operating levels in raspi-config.
thx
Sven
jordipalet
Sun Dec 09, 2018 8:29 pm
New with Raspberry and using the Pi 3 Model B+ with the PoE Hat.
Had the same problem with the fans running too much even with normal 45C, so followed those instructions and changed in the code published by dr.sputnik, compatible = "rpi-poe-fan"
I still got
after the sudo dtc -@ -I dts -O dtb -o rpi-poe.dtbo rpi-poe-overlay.dts
ignored it, done a chmod +x and copied over to /boot/overlay (backed up first).
However, no results with sudo dmesg -C
and sudo dmesg -w, doesn't provide anything ... need to ^c, as not coming back to the prompt
Is that normal?
Or there is an alternative way to do this since september with this thread was published -?
(I've everything updated to the last version)
Thanks!
Change:
Back to:
Thanks Martin
ShiftPlusOne
Tue Dec 11, 2018 4:25 pm
It's a bit simpler now. Restore the original overlay.
https://github.com/raspberrypi/firmware ... ADME#L1646
In config.txt:
dtparam=poe_fan_temp0=55000,poe_fan_temp1=60000
That should turn the fan on at 55C
jordipalet
Tue Dec 11, 2018 5:32 pm
Thanks a lot, it worked only issue is that params seems to work this way:
In config.txt:
dtparam=poe_fan_temp0=55,poe_fan_temp1=60
ShiftPlusOne
Tue Dec 11, 2018 6:06 pm
Yes, sorry I was in a hurry. I'll edit the post so it doesn't trip others up.
bobbyiliev
Sat Feb 09, 2019 9:03 pm
This works great!
In config.txt:
https://bobbyiliev.com
maltwix
Mon May 27, 2019 5:36 pm
In config.txt:
Hi ShiftPlusOne,
unfortunately this does not work on my RPI. I have the newest version of raspbian (downloaded 2 days ago). I added the following in my config.txt:
dtoverlay=rpi-poe:poe_fan_temp0=59000,poe_fan_temp1=60000
and output from vcdbg log msg:
002294.543: Loaded overlay 'rpi-poe'
002294.598: dtparam: poe_fan_temp0=59000
002301.831: dtparam: poe_fan_temp1=60000
But Fan does still turn on at 50000...
It would be great if you can help me.
ShiftPlusOne
Wed Jun 05, 2019 4:21 pm
Just tried your settings and it seems to work for me.
What's in /sys/class/thermal/thermal_zone0/trip_point_1?
Are you sure it's coming on at 50 and you're not just seeing it remain on while the temperature drops down from 59?
maltwix
Mon Jun 10, 2019 3:46 pm
The files are named like this:
-r--r--r-- 1 root root 4096 Jun 9 15:18 cdev0_trip_point
-r--r--r-- 1 root root 4096 Jun 9 15:18 cdev1_trip_point
-rw-r--r-- 1 root root 4096 Jun 9 15:18 trip_point_0_hyst
-r--r--r-- 1 root root 4096 Jun 9 15:18 trip_point_0_temp
-r--r--r-- 1 root root 4096 Jun 9 15:18 trip_point_0_type
-rw-r--r-- 1 root root 4096 Jun 9 15:18 trip_point_1_hyst
-r--r--r-- 1 root root 4096 Jun 9 15:18 trip_point_1_temp
-r--r--r-- 1 root root 4096 Jun 9 15:18 trip_point_1_type
And now I have the correct settings in it because I rebuilt the dtbo file with the settings I want to have. This is wokring now...
Kondziu
Thu Jul 11, 2019 5:47 pm
I'm in the same boat - configuration for the PoE hat in /boot/config.txt does nothing for me, while .dtbs modifications do the trick.
bibou65
Tue Jan 14, 2020 7:48 pm
Hi all,
I have a Raspberry Pi 4 (4GB) and a POE HAT and I also encounter difficulties to manage the fan of the POE HAT.
I have a standard Pi4 case (red and white) and my Pi only have a Ubiquiti controler and PiHole installed. The temperatur of the PI is always around 75 C° when the system is running (let say idle state). If I start playing with the Ubiquiti controler and the PiHole, it easily get to 82 C° and I'm scared that something start braking due to the temperature to high.
For the moment I have disabled the fan because it ran like 5 seconds every 15 seconds and it is very noisy/annoying.
I have tried to follow the steps above in this post but with my poor linux and dev knowledge, I can't figure out what I have to do.
I have tested the line:
in the /boot/config.txt and change the values to test but nothing is changing the fan still run every 15 seconds etc.
I have tried to check the links below but I feel completely lost with it. I don't know what to do with all these text/overlay stuff and where to install/place the content/files:
https://github.com/raspberrypi/firmware ... 78cb40e6e4
Is there any "easy" stuff for basic users to manage the fan of the POE HAT just like the https://shop.pimoroni.com/products/fan-shim?
Thanks in advance :)
T1NBK
Sun Apr 05, 2020 8:41 pm
I tested with poe_fan_temp0 and poe_fan_temp1 but found I was only able to set a lower setpoint for starting the fan.
RBP 3B+ with raspberry buster
I looked at the overlays in the firmware/README and found the following
poe_fan_temp0 Temperature (in millicelcius) at which the fan
turns on (default 50000)
poe_fan_temp0_hyst Temperature delta (in millicelcius) at which
the fan turns off (default 5000)
poe_fan_temp1 Temperature (in millicelcius) at which the fan
speeds up (default 55000)
poe_fan_temp1_hyst
So I also added the hyst params and now I'm able to set a higher setpoint.
dtparam=poe_fan_temp0=60000,poe_fan_temp0_hyst=5000,poe_fan_temp1=65000,poe_fan_temp1_hyst=5000
I'm not sure what the lowest possible RPM is and how much noise the fan makes at those RPM but the idea I have is to keep the fan running at it's lowest RPM when the system is idle and use a PID control to keep it below a certain setpoint.
For me its not the fan itself that is annoying. Its the constant starting at (too) high RPM and then stopping again cyclus that gets annoying.
brontide
Mon Apr 27, 2020 5:42 pm
Using the latest firmware I've applied the following options to make my rPi 4 k8s cluster nearly silent. A low, barely audible, fan will kick on at 55 and be audible but still quiet at 65; it should not start being noisy until 71 which is still below thermal throttling of 83/85 for this device, the full fan speed kicks on at 73. Running CPU intensive workloads I was unable to push it past the second setpoint.
dtparam=poe_fan_temp0=55000,poe_fan_temp0_hyst=5000,poe_fan_temp1=66000,poe_fan_temp1_hyst=5000
dtparam=poe_fan_temp2=71000,poe_fan_temp2_hyst=5000,poe_fan_temp3=73000,poe_fan_temp3_hyst=5000
What's odd is that it appears to map the values in reverse, so temp0 = trip_point_3_temp. I'm going to try messing with the device tree since I think a lot more could be done with the cooling levels by having more cooling steps at lower PWM levels.
As a benefit the lower fan speeds appear to shave ~1W of power usage off the units ( measured at PoE switch ).
brontide
Tue Apr 28, 2020 11:55 pm
Okay, another day where I spent some quality time with the code. I've modified the overlay to give more steps in the quiet range of the fan. I've patched the firmware overlay with new trip levels and it's really useful.
cooling-levels = <0 15 31 63 255>;
Temperature trips are set to 43, 58, 69, and 78 with hysteresis at 1, 2, 9, and 9 degrees ( multiply all numbers by 1000 for the dtparam ). With the quiet end of the range it's easy to have minimal hysteresis but as you go up you need to raise it in order to prevent the cycling that is so annoying.
jordipalet
Wed Apr 29, 2020 10:16 am
I wonder if this should also work with the last firmware of the Pi 3 Model B+ with the PoE Hat.
The fan never stay on in the "lower" possible speed, so the problem is the fan on/off noise ...
Also I've another problem which I'm not sure is related to the heat or what. From time to time (typically every week), I like to reboot the Pi, for example, after a firmware upgrade. The system seems to work, but the Ethernet, even if blinking, is not reachable (no ping, no ssh). I usually need to use the switch interface to power it off, then power it on and most of the time, just doing this once, it works (some times I need to do it once more).
The Pi is in a Dlink PoE swith wich many other POE devices on it. All the other devices don't have any trouble, so I don't think it is a switch problem.
brontide
Wed Apr 29, 2020 4:06 pm
I think it's the same firmware so the same fix should work. The trick with the noise is to make sure the hyst is high, that way when it steps up it's going to take longer to step down. Without knowing your workload and ambient temp it's hard to make any hard recommendations but you can watch.
$ cat /sys/class/thermal/cooling_device0/cur_state
1
$ cat /sys/class/thermal/cooling_device0/stats/time_in_state_ms
state0  1
state1  78601953
state2  3075
state3  0
state4  0
$ # if you don't see 5 states then you're on an older kernel device tree and will have fewer trip points to configure.
To see where your device is spending more time. If it's cycling in a state too frequently you want to increase the temp separation AND the hyst so that is goes into that state less frequently and stays there longer. That's actually a mistake in my first example, the temperatures should be further apart because hyst will be capped to min(value, abs(temp-next step), abs(temp-previos step)). If your step is only 2 degress the hyst will be capped there as well. If you use 40, 50, 60, 75 ( nice, spread out values ) you can raise the hyst to 10,10,10,15 which should keep the fans on longer at whatever speed the step up to.
Can't be help there, mine reboot no problem using either `reboot` or `shutdown -r now`. I've got my units attached to a Ubuquiti US-8-60w without complains.
geoffr
Wed May 20, 2020 11:18 am
I've made a similar change. I'm happy running my lowest fan speed up to 55 degrees, and instead of using 15 as the PWM value, I am using 10. It would be useful for the overlay not to have the PWM values hard-coded, but rather to allow them to be changed in config.txt. I have however not spent long enough looking at how overlays are written to work out how to change that.
r59f9
Thu May 28, 2020 4:31 pm
I have two 3B+ set up with the PoE HAT. For months I've had them happily running with the following in /boot/config.txt to control when the fans run:
# to regulate when the fan comes on and off
dtparam=poe_fan_temp0=60000,poe_fan_temp1=65000
I ssh in and run apt update/upgrade a couple of times a week. I did that today as usual and there were a few updates installed.
Since then, both of the Pis appear to have stopped controlling the fan according to the above settings. It seems that the fans now come on when the temperature hits 50C - which if I think is maybe the default if not overridden?
I've done a bit of checking, turning one off at a time, and they both appear to be doing the same thing with the fans after the same software updates today.
One (possibly both) of the Pis has started intermittently making that high pitched noise on and off, possibly in association with the fan being triggered frequently due to the settings not working. As the temperature seems to hover around 50C most of the time, the fans come on a lot, sometimes for just a half second at a time. Sounds like someone wheezing and whistling in the corner, which is quite annoying as the Pis are in my home office so I'm hearing this all the time.
Has a recent Raspbian update changed how the PoE HAT fan is regulated? If so, what can I change to adjust the settings back to something closer to what I had before?
Thanks!
r59f9
Fri May 29, 2020 11:25 am
To follow up on my post above, it seems that some changes have been made, discussed in recent posts on this Github page: https://github.com/raspberrypi/linux/issues/2715
I've still been unable to work out what I need to change to restore the functionality. Whatever I do, the fan appears to run on default settings.
After numerous attempts I've opted to disable the fan altogether by entering disable_poe_fan=1 as a line in /boot/config.txt
Any tips on what's needed would be appreciated.
r59f9
Fri May 29, 2020 12:08 pm
OK I managed to get it working with the following entry, which starts the fan at 60C and increases intensity if temp increases above the additional thresholds:
# fan activation and escalation settings
dtoverlay=rpi-poe
dtparam=poe_fan_temp1=62000
dtparam=poe_fan_temp2=64000
dtparam=poe_fan_temp3=68000
