hello
i use https://www.raspberrypi.org/documentati ... s-point.md tutorial to make my raspberry pi 3 an access point with it's built in WiFi. so when the access point mode start the pi internet disconnects.
now i want to switch to the mode before turning to access point(station mode) which works with raspberry built in WiFi.
what are the commands?
is it possible to do it with only on or two command and doesn't reboot the raspberry?
