#ask
today im trying to boot my pi,but suddenly the green light is not on nor blinking.is my raspberry fried or something?,because i use my usb port from my laptop for the power supply before,if its fried,is there a way to fix it?
If you dont use the proper recommended power supply for your RPi, then there is no way to fix the problem.
Come to me with 'problems' and I'll help you find solutions" Some people be like:
What kind of USB port does your laptop have? Which model of Pi did you try to run from it? did you try to power the Pi through its normal power connection, or by some other means, such as GPIO pins?
At a guess, the laptop may not have been able to maintain 5v output and--depending on the model of Pi--may not have been able to supply enough current. This could have led to corrupting the SD card.
