mariusmilatz
Python Script 'Invalid Syntax'
Fri Aug 17, 2018 9:55 am
I am not very familiar with any of raspberry pi product or the scripts used to program them.
The result i am trying to accomplish:
- I am trying to create a camera with a trigger switch for recording. (when trigger pressed the camera records, when released the camera stops recording).
- Trigger switch input is 3v when not pressed & 0v when pressed.
- The script should run every time the raspberry pi is turned on.
The script that i used: ((sample.py) - saved file name)
import time
import datetime
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
GPIO.setup(29,GPIO.IN,pull_up_down=GPIO.PUD.UP)
def startrecording()
	raspivid -t 600000 -ex auto -b 17000000 -o /home/pi/t1_'date+%d%m%Y_%H%M-%S'.h264
def stoprecording()
	pkill raspivid
while True:
	GPIO.wait_for_edge(29,GPIO.FALLING)
		startrecording()
	GPIO.wait_for_edge(29,GPIO.RISING)
		stoprecording()
The script after 'while True' should be on a continues loop.
To make the script run on startup i:
sudo nano /etc/rc.local
(edited the script)
sudo python /home/pi/sample.py
(line above 'Exit 0')
Once i rebooted the raspberry pi i got a 'Invalid Syntax'
Can anyone help me as i really don't know what i am doing?
PeterO
Re: Python Script 'Invalid Syntax'
Fri Aug 17, 2018 10:04 am
mahjongg
Fri Aug 17, 2018 10:37 am
added code tags, and moved to python section
mariusmilatz
Fri Aug 17, 2018 10:43 am
Do you mean instead of this:
while True:
startrecording()
stoprecording()
Write this:
If true :
do_this startrecording()
do_this stoprecording()
Fri Aug 17, 2018 11:18 am
1) You did say in the OP "The script after 'while True' should be on a continues loop." So "while True" would be the thing not "if"
2) Your "if true" would be useless. "True" is always true so the test is redundant.
3) Did you mean "if True". I think using a lower case "true" is an error.
4) Without proper indentation your code will fail at the "if" clause.
5) You did not use code tags around your example so it's gibberish anyway.
DirkS
Fri Aug 17, 2018 11:21 am
mahjongg added them more than half an hour before you posted this...
You should also be able to see the indentation when you quote the post
mariusmilatz
Fri Aug 17, 2018 11:38 am
I am quite confused now.
This is the code that i am using at the moment which gives me the 'Invalid Syntax' message.
import time
import datetime
def stoprecording()
	pkill raspivid
while True:
		startrecording()
		stoprecording()
- Should I be using 'while True' or 'if True'?
-Code tag. "pkill raspivid" or pkill raspivid. is this what is meant by code tags?
[MOD Edit, again added code tags]
elParaguayo
Fri Aug 17, 2018 11:49 am
As above, please make sure your code is in code tags (read the link in PeterO's post). Without it, we lose the indentation and your code will make no sense.
Next, when posting about python errors, post the whole error message (which includes line references) so we can home in on the relevant part.
The bits that immediately jump out at me are:
def stoprecording()
    pkill raspivid
The raspivid and pkill lines are not python commands and so the python interpreter won't know how to handle them.
To run shell commands, you need to use the subprocess module. Something like this:
import subprocess
    subprocess.call(["raspivid", "-t", "600000", "-ex", "auto", "-b", "17000000", "-o", "/home/pi/t1_'date+%d%m%Y_%H%M-%S'.h264"])
def stoprecording()
    subprocess.call(["pkill", "raspivid"])
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
mariusmilatz
Fri Aug 17, 2018 12:05 pm
Just put the subprocess code into the script:
import time
import datetime
import subprocess
def stoprecording()
while True:
                startrecording()
                stoprecording()
The error message is:
pi@raspberrypi:~ $ sudo python /home/pi/super8.py
  File "/home/pi/super8.py", line 9
SyntaxError: invalid syntax
elParaguayo
Fri Aug 17, 2018 12:31 pm
When you define functions, you need a colon at the end of the line:
def startrecording():
Update your code throughout (and, yes, I missed it when I commented on using subprocess!)
mariusmilatz
Fri Aug 17, 2018 12:44 pm
The new code is
import time
import datetime
import subprocess
def stoprecording():
while True:
                startrecording()
                stoprecording()
when i run the new code i get this:
  File "/home/pi/super8.py", line 10
SyntaxError: Non-ASCII character '\xe2' in file /home/pi/super8.py on line 10, but no encoding declared; see http://python.org/dev/peps/pep-0263/ for details
I have check the http:// address but doesn't make much sense to me. do i have to put "#!/usr/bin/python" in the script?
elParaguayo
Fri Aug 17, 2018 12:49 pm
You can try putting this at the very top of your file
# -*- coding: utf-8 -*-
However, it shouldn't be necessary here and I'm not sure why you're getting that message as there's no obvious stray character in your code.
EDIT: I wonder if it's to do with this: /home/pi/t1_'date+%d%m%Y_%H%M-%S'.h264
Can you just try with a simple filename to start with e.g. /home/pi/t1_test.h264
mariusmilatz
Fri Aug 17, 2018 1:09 pm
the error was happening due to the spaces after the ',' signs.
The error that i am now getting is:
pi@raspberrypi:~ $ sudo python super8.py
  File "super8.py", line 8, in <module>
AttributeError: 'module' object has no attribute 'PUD'
Do i even need the code 'pull_up_down=GPIO.PUD.UP' part?
The GPIO pin 29 is connected to a wire which is at 3v. when i press the trigger the wire voltage goes to 0v. when i relies the trigger the wire voltage goes back to 3v.
This is how i want to stop and start the RPi to stop and start recording.
DirkS
Fri Aug 17, 2018 1:14 pm
It's PUD_UP instead of PUD.UP
mariusmilatz
Fri Aug 17, 2018 1:30 pm
Thanks. Now there is no error message.
For some reason the camera doesn't start recording when i press the trigger.
Do i have to import picamera to script?
elParaguayo
Fri Aug 17, 2018 2:42 pm
You don't need to import picamera if you're calling a shell script (whether that is the best way to use the camera is beyond my expertise as I've never used the camera but I'd normally prefer to use python bindings rather than call external scripts).
As for your code not starting, you could put some print statements in the code to debug and see what's happening (just add the print statements to your current code, don't copy this):
        print("In startrecording")
        print("Leaving startrecording")
        print("In stoprecording")
        print("leaving stoprecording")
while True:
        print("Entering loop.")
        print("Waiting for falling edge...")
                print("Falling edge. Calling startrecording")
                startrecording()
        print("Waiting for rising edge...")
                print("Rising edge. Calling stoprecording")
                stoprecording()
        print("Restarting loop")
Another idea, you should probably change the raspivid command to subprocess.Popen rather than subprocess.call as call waits for the command to finish before continuing.
mariusmilatz
Fri Aug 17, 2018 3:02 pm
Yes, i will try that.
Thanks anyway for helping me.
Big help.
mariusmilatz
Sun Aug 19, 2018 4:02 pm
Do you know by any chance know how to create a hold button function in python.
at the moment the trigger signal is slightly occulting and coursing the edge detection to go off unintentionally.
the script that i am using:
import datetime
import subprocess
GPIO.setup(37,GPIO.IN,pull_up_down=GPIO.PUD_UP)
    print("leaving startrecording")
while True:
    print("Entering loop")
    GPIO.wait_for_edge(37,GPIO.FALLING)
    print("Faslling edge. Calling startrecording")
    startrecording()
    GPIO.wait_for_edge(37,GPIO.RISING)
    stoprecording()
so the RISING edge is the problem. if i could get something like, if edge changes longer then 1 second execute 'stoprecording()'
mariusmilatz
Sun Aug 19, 2018 4:04 pm
oscillating*
Return to “Python”
