RichInTheUSA
Error installing python-mlt_6.4.1-4_amd64.deb
Mon Aug 13, 2018 1:27 am
Hello, I am trying to install python MLT on my mac laptop, which has an AMD64 processor.
I can successfully download the AMD64 file from here: https://packages.debian.org/stretch/amd ... t/download
However, after downloading and double clicking in the File Manager... I get the error message Failed to install file: A package could not be found that allows the action to complete. More information is available in the detailed report.
Anyone have an idea where the detailed report is located?
Thanks!!
bertlea
Re: Error installing python-mlt_6.4.1-4_amd64.deb
Mon Aug 13, 2018 7:30 am
If you are installing it to the "Raspberry Pi Desktop", I believe you need to install the i386 (32-bit) version, because, to my understanding, the Raspberry Pi Desktop for PC and Mac is only 32-bit OS regardless what CPU you got.
I was also confused by that initially as the website typically seems able to detect my system is 64 bit and provide the 64-bit packages, but then it failed and I need to download the 32-bit to make it work.
RichInTheUSA
Mon Aug 13, 2018 1:44 pm
Thank you for the response above! I installed MLT for the i386 and that install worked! However, when I then went to run OpenShot (which was failing because MLT was a dependency) it opened, but then the whole box hung after about 15 seconds. No error messages. The box just froze up.
I may just try Blender instead. I know it's not made for video editing... but I hear it can be used for that purpose. I'm really just looking for any video editing software that works... even something basic. :)
Thanks again!!!
Mon Aug 13, 2018 2:59 pm
Thanks!!
Debian Stretch with RPD is 32bit userland though it will choose the appropriate kernel for you architecture, there are several post in this section of the forum.
The correct way to install Debian packages and save a lot of hassle regarding wrong architecture and dependencies is:
sudo apt update
sudo apt install python-mlt
https://packages.debian.org/stretch/python-mlt
adieu
My other Computer is an Asus CS10 ChromeBit
Return to “Raspberry Pi Desktop for PC and Mac”
