MatsPojken
One of my Pi:s cannot connect to internet, needs 192.168.x.x, gets 169.254.x.x.
Sat Aug 11, 2018 12:11 pm
One of my Pi 1 B, running Stretch, does not get a good IP address in order to connect to internet. It gets 169.254.126.50, but only this Rpi does. All of my other RPi:s, 1B, 2 and 3, running Weezy, Jessie or Stretch get working 192.168.xx.xx adresses.
"route -n", with the failing RPi, shows only the wrong route, "169.254.0.0".
I have read a lot of topics in this Forum and tried several activities to fix the problem, but without success:
* Static or dynamic addresses
* Switching ethernet cable
* Switching RPi:s into the 'failing' cable set
* Checking the router: No MAC filtering
* Checking the router: IP address interval is wide enough
* Restarting the router with and without power down and with or without a power down pauses
What more could be done?
Re: One of my Pi:s cannot connect to internet, needs 192.168.x.x, gets 169.254.x.x.
Sat Aug 11, 2018 7:20 pm
Have you eliminated
1. Bad port on router/switch
2. Bad WiFi credentials
3. Bad Raspberry power supply (any sign of the on-screen lightning bolt)
drgeoff
Sat Aug 11, 2018 8:02 pm
Swap the SD cards of the "bad" RPi and one of the "good" ones, Does the problem move with the card or stay with the RPi?
andrum99
Sat Aug 11, 2018 9:44 pm
That IP address indicates that the machine has been unable to contact a DHCP server, so has made up an IP address for itself.
Try connecting the problem Pi to the same port on the router/switch as the working Pi using the same cable. If this fails, then it is either a software problem on the Pi, or there is a hardware fault on that Pi (unlikely but possible).
andrum99
Sat Aug 11, 2018 9:48 pm
And use the same power supply plugged into the same power socket as well.
Shadow_7
Mon Aug 13, 2018 2:56 am
Seems like avahi-daemon is stomping on your toes. (steps on mine too). It sets up a default ip/route when it thinks it didn't find one. Which overrides the route you "want" to take.
$ sudo ip addr del 169.254.156.66/16 dev eth0
$ sudo ip route add default via 192.168.1.1 dev eth0
Is a regular part of my first steps after bootup. Along with manually setting up my network.
$ sudo ip link set eth0 up mtu 1500
$ sudo ip addr add 192.168.1.99/24 dev eth0
Replace with the specs for your system.
$ ip link show
$ ip addr show
$ ip route show
Having the 7" touchscreen helps since I can "see" what I'm doing.
MatsPojken
Mon Aug 13, 2018 8:08 am
Have you eliminated
@DougieLawson
1 and 3 are eliminated (forgot to add it in my list), but I'll go for 2 in a while. Thanks
MatsPojken
Mon Aug 13, 2018 8:16 am
@andrum99, I didn't perform exactly this switch before, but now i have. Sorry, no success, still 169.254.x.x, Thanks
MatsPojken
Mon Aug 13, 2018 8:21 am
@drgeoff, Test now performed: SD with Stretch lite instead of Stretch: no success. Thanks
MatsPojken
Mon Aug 13, 2018 8:38 am
$ ip link show
$ ip addr show
$ ip route show
@Shadow_7, Interesting, I didn't know that I can add a route lika that. Anyway, the "sudo ip addr del...." removed the one route I had and the "sudo ip route add default..." was followed by.
RNETLINKANSWERS: Network is unreachable
and I have no routes at all.
It starts to look like a hardware problem, but first I have to take a trip with my bike (electrical, but not connected) to consider everything. It may help - with a little help from my friends... Thanks for now.
@Shadow_7, Adding the 192-route keeping the 169-route is possible, but how do I test it? Reconnecting the cable after some pause?
@Shadow_7, Unplugging cable, then adding 192 with 169 still there adds 192 in the route -n result. Then removing the 169 route also removes the 192 route and I have zero routes left. /MatsPojken after bike trip
