I am on my fourth try with Raspbian on Raspberry Pi 3 Model B+. The first three times, I installed NOOBS. This fourth time, I installed from a downloaded image. All four times, I have no problem getting started. The problems start later.
I don't see a login screen for weeks when I boot the machine. Many, many boot cycles later, the login screen comes up but won't accept the password I entered. (At the first complete restart, I taped the password to the monitor so I wouldn't forget it!) I used recovery mode to edit cmdline.txt so I could enter the command shell, remounting the volume and execute the passwd command. I was heartened to see the "password successfully changed" message, but still I could not login.
So, now I am starting all over again for the fourth time. Many weeks of work lost. Again.
Booting from the Debian image and stepping through the initial configuration process, I again see no login screen at boot. So, I suspect I will run into the same problem all over again and lose more weeks of work.
Can someone, please, explain what I am doing wrong.
