For me using the octopi distro wasted time, not real-time enough?
I was suspecting it was the distro that was the problem, could see in temp graphs that it was dropping way below target temps such that the firmware stopped extruding! and bed temp dropped so much that object warped off the plate... how many hundreds of hours wasted because trying to save a few hours!!!! wasted prints... after wasted prints.... though did get some ok prints off the octopi distro, more **** than good!
manual install of octoprint is straightforward following the instructions, I dont need any cam stuff or want port 80 or https... s.t.m. something somewhere in the distro is hogging cycles that are those required for the sending of info at the speed it is consumed....
well that's my opinion... maybe other printers work better, but my self built k8200/3-drag works better with current raspbian with manual installed octoprint....
maybe would even work on an old pi-b (as it used to when I first built printer several years ago), it is working on a pi-3 at the moment. and I did disable wifi and bluetooth.
now feeling comfortable I can spare some cycles to run top over an ssh connection, can see even now octoprint occasionally pops up at 35%+ of a pi3 core though 90% of the time runs at about 1-3% of a pi-3 core.
