andre_teprom
How to add a script "before" system boot ?
Sat Aug 04, 2018 3:23 pm
I'm using the Linux headless (graphical interface deactivated) at RPI3, and I wanted to run a script right before the boot process.
If I add something on the contab ( e.g @reboot option ), this is instatiated at the end of the booting process.
Does someone know how to do that ?
thagrol
Re: How to add a script "before" system boot ?
Sun Aug 12, 2018 2:35 pm
Probably can't be done. Although that depends on what you mean by "right before the boot process".
The best you're likely to get is a systemd service configured to run as soon as everything your script depends on is available. Good luck working that out.
Note to self: don't feed the trolls
If I've asked you a question, please answer it. I'm unlikely to be able to help without that information.
Return to “Raspbian”
