WillBoxOwO
Keyboard shortcut doesnt output random numbers
Sat Aug 04, 2018 1:50 am
Hello there.
Im trying to configure a keyboard shortcut on Raspbian using the default GUI environnement, Openbox.
Im using the following piece of code I wrote to take screenshots using the raspi2png library wich supports OpenGL capture.
I modified the following configuration file: /home/pi/.config/openbox/lxde-pi-rc.xml
My goal is simple; When I hit CTRL+Alt+P, I want it to take a screenshot named with a random number.
Here is the code:
    </keybind>
    <keybind key="C-A-P">
      <action name="Execute">
        <command>raspi2png -p Desktop/Screenshots/snap${RANDOM}.png</command>
      </action>
    </keybind>
Dont get me wrong; it works. But the "${RANDOM}" doesnt output a random number; it simply outputs "${RANDOM}".
Buut I tested the command in lxterminal and it outputs the random number...
What am I doing wrong?
Cheers.
I like cats
Re: Keyboard shortcut doesnt output random numbers
Sat Aug 04, 2018 5:07 am
Try changing it from
to
        <command>raspi2png -p Desktop/Screenshots/snap$(shuf -i 0-32767 -n 1).png</command>
Note: I've not tested that.
WillBoxOwO
Sat Aug 04, 2018 4:39 pm
Thanks for the reply! Sadly, it doesnt work. It works only in the terminal. The keyboard shortcut doesnt even take the screenshot using this command!
I then modified the command as follow:
raspi2png -p Desktop/Screenshots/snap.png
And it works flawlessly using the keyboard shortcut- but theres no random number at the end of the file...
Would there be a way to launch the terminal in the background and make it run the command?
I like cats
klricks
Sat Aug 04, 2018 4:57 pm
Try:
lxterminal -e raspi2png -p Desktop/Screenshots/snap$(shuf -i 0-32767 -n 1).png
Paeryn
Sat Aug 04, 2018 4:58 pm
The command isn't being run by a shell so ${RANDOM} is being used literally, on the command line bash will replace that with a random number but since bash isn't invovled here it doesn't happen.
If you want to use shell features you can run it via bash yourself, something along the lines of
<command>bash -c 'raspi2png -p Desktop/Screenshots/snap${RANDOM}.png'</command>
WillBoxOwO
Sat Aug 04, 2018 5:34 pm
Try:
Again, it only works using the terminal... No screenshots are taken!
Plus, even if it worked, the screenshots wouldnt have worked out since it pops an lxterminal window everytime. Thanks tho!
Yay! This one seems to works! Thanks alot my friend!
I like cats
