Bringamosa
How to get GUI to show
Sat Aug 04, 2018 12:22 am
Hi all.
I have a .jar program that runs smoothly on windows. If i double click the file it opens a GUI and i can use the program.
However when i try to run the file on my rpi 3 it will not open the GUI. I tried double clicking it and nothing happens.
When i try to run it using this command: java -jar filename.jar
i get this response:
4-aug-2018 1:52:47 config loaded
4-aug-2018 1:52:47 failed to create GUI:
4-aug-2018 1:52:47 java.lang.reflect.InvocationTargetException
	java.awt.EventQueue.invokeAndWait(EventQueue.java:1349)
	java.awt.EventQueue.invokeAndWait(EventQueue.java:1324)
	traviaut.Main.main(Unknown Source)
4-aug-2018 1:52:47 TraviAut
4-aug-2018 1:52:47 Version: 20180307.0
4-aug-2018 1:52:47 Java version: 1.8.0_181
4-aug-2018 1:52:47 TO AVOID CAPTCHA FILL IN YOUR USER_AGENT IN SETTINGS
How do i get the "failed to create GUI" error fixed?
I hope you can help me out here if more info is needed please let me know and i will provide.
B.Goode
Re: How to get GUI to show
Sat Aug 04, 2018 7:15 am
Welcome to the Raspberry Pi forums.
Perhaps this is a question that should be addressed to the author of the application you are trying to run?
But just as a guess... From http://www.traviaut.com
Getting started in 3 easy steps
Click settings and fill in your User Agent. You can get your User Agent here
That seems to correspond with the text emitted by the application -
Have you done that?
Bringamosa
Sat Aug 04, 2018 7:52 am
Hi thank you for looking at my problem.
I have contacted the author too waiting for a response still. I have had it working on lubuntu like a year back or so i thought it would work on rapsbian too.
About filling in the user agent, that is the message the application will show in the GUI when running it. I'll hav a look and see if i can find where it is saved.
Return to “Java”
Who is online
Users browsing this forum: Google [Bot] and 2 guests
