JonnyAlpha
Raspberry Pi Certified Educator
Cannot Install Moviepy for Python 2.7
Fri Aug 03, 2018 12:37 pm
Hi;
I am trying to follow this tutorial for OpenCV robot vision:
https://www.hackster.io/kemfic/simple-l ... 3db2f?f=1#
However I am having trouble with the module 'moviepy'.
I am trying to install it using
sudo pip install moviepy
but the output suggests that the Requirement is already satisfied, the list of locations however are all python 3.5.
How do I force it to install it for Python 2?
Raspberry Pi Certified Educator. Main Hardware - Raspberry Pi 1 model B revision 2, Raspberry Pi 2 model B, Pi Camera
JonnyAlpha
Re: Cannot Install Moviepy for Python 2.7
Fri Aug 03, 2018 12:46 pm
Mmm I re-read details on installing packages and
sudo pip install xxxxx
should install the module for python 2 and
sudo pip3 install xxxx
for python 3.
In an act of desperation I tried
sudo pip2 install xxxxx
and it worked - how bizzare - it was not documented
