Ayvazofsky
Troubles with YOLO on Raspberry Pi 3 B+
Fri Aug 03, 2018 6:51 am
Hi everyone recently I bought Raspberry Pi 3 B+ and install Raspbian I compile YOLO and try to run it, but when i run program i get Under-voltage detected! (0x00050005) and program doesn't run. Can anybody help me solve this problem? Who try YOLO on Raspberry? Any answer can help.
Thank you in advance.
Re: Troubles with YOLO on Raspberry Pi 3 B+
Fri Aug 03, 2018 9:54 am
Use a better power supply to get rid of the undervoltage.
As for Yolo not running, if the Pi is dying due to low power that would stop it working, but I suspect it might be something else. Sort out the power supply first, then we can progress.
Ayvazofsky
Fri Aug 03, 2018 7:26 pm
Thanks a lot...I have corrected it...and received 0.1 FPS(( :o :oops:
Is'it maximum for Raspberry Pi?
Fri Aug 03, 2018 9:31 pm
What is Yolo and what are you trying to do with it? If it is very CPU intensive, or memory hungry, then you have to remember the Pi is not a 8 core $1000 desktop with 16GB of RAM.
Ayvazofsky
Sun Aug 05, 2018 9:10 am
Is it impossible to obtain normal real time object recognition on raspberry? (at least 8 FPS). Thanks.
Sun Aug 05, 2018 10:10 pm
Well, you need to find out what sort of CPU instructions per second would be required, then compare that with the Pi performance figures. I have no idea about Yolo, so difficult to make a judgement.
Ayvazofsky
Mon Aug 06, 2018 5:31 am
Thanks a lot Jamesh...
MouseNJ
Sun Aug 19, 2018 6:17 am
Do you mean YOLO( You only look once), the convolution neural network algorithm to detect objects in a video stream? 0.1 FPS is very slow because of the limited RAM and computation speed. Image size and model parameter complexity also matters. I have little experience in optimization but you can have a try. Are you using MXNET?
kdupreez
Tue Aug 21, 2018 6:07 am
Even with YOLO "Tiny" and a single class trained network configured for small 256x256 network input it takes 4.2 seconds per image..
VERY slow on RP3B+ without any GPU :(
Ayvazofsky
Thu Aug 23, 2018 10:54 am
No I'm not used MXNET...but its look like I found solution. Using SSD (Single Shot Detection) and Movidius NCS Stick you can get 6-8 maybe 10 FPS...And i think that's great.
DanielChai
Wed Aug 29, 2018 3:13 am
First, don't think about running Yolo full version on RPI! Forget it!
Second, running Yolo tiny is totally possible. There are some optimization you can do to improve its FPS on RPI. The original darknet had poor performance on CPU (it was designed to run on CUDA GPU). You have to compile the darknet code with NNPACK to do parallel computation on multicore CPU.
Still, no way you can get 8-9 FPS without additional hardware like Intel Movidius.
I successfully ran Yolo v3 tiny on my Pi 3 model B+ and get 1FPS. Not too bad for trivial usage..
Check the results here
http://funofdiy.blogspot.com/2018/08/de ... real.html
Ayvazofsky
Wed Aug 29, 2018 11:59 am
DanielChai wrote: First, don't think about running Yolo full version on RPI! Forget it!
Thanks I'll take your advice into account))
Try to get 8 FPS)
victagayun
Thu Nov 15, 2018 6:47 am
I logged new issue on github.
https://github.com/shizukachan/darknet-nnpack/issues/18
@ Install qmkl
sudo apt-get install flex
git clone https://github.com/Terminus-IMRC/qpu-assembler2
cd qpu-assembler2
cmake .
CMake Error at CMakeLists.txt:22 (message):
  qasm2 not found.  Install it from
-- Configuring incomplete, errors occurred!
See also "/home/pi/qmkl/CMakeFiles/CMakeOutput.log".
Follow, clone and make https://github.com/Terminus-IMRC/qpu-assembler2
and install flex.
Then got this 2nd error
pi@raspberrypi:~/qmkl $ cmake .
CMake Error at CMakeLists.txt:27 (message):
  qbin2hex not found.  Install it from
  https://github.com/Terminus-IMRC/qpu-bin-to-hex
Follow and clone and make https://github.com/Terminus-IMRC/qpu-bin-to-hex
The last error I cannot solve anymore.
-- Checking for module 'libmailbox>=2.0.0'
CMake Error at /usr/share/cmake-3.7/Modules/FindPkgConfig.cmake:415 (message):
  A required package was not found
Call Stack (most recent call first):
  /usr/share/cmake-3.7/Modules/FindPkgConfig.cmake:588 (_pkg_check_modules_internal)
  CMakeLists.txt:52 (pkg_check_modules)
I did this on fresh Raspbian.
Drallert
Thu Nov 22, 2018 8:29 pm
Ayvazofsky wrote: Is it impossible to obtain normal real time object recognition on raspberry? (at least 8 FPS). Thanks.
I've managed to get it to ~0.5 fps compiling with openmp option activaded, but that's still not enough
We'll have to figure out somehow, like this guy: https://www.youtube.com/watch?v=nTQHUsKE-xo
He doesn't give documentation though
DanielChai
Wed Dec 19, 2018 7:44 pm
If I have to guess, he might be using some USB deep learning accelerator like this
https://www.youtube.com/watch?v=MK7XExpfm7Q
Return to “C/C++”
