spidey57
RollerCoaster Tycoon2 with OpenRCT2 on Raspberry Pi 3b+
Tue Jul 31, 2018 4:24 pm
Running on a RaspberryPi3B+ with latest Raspbian
RASPBIAN STRETCH WITH DESKTOP
Image with desktop based on Debian Stretch
Version:June 2018
Release date:2018-06-27
Kernel version:4.14
Download the sourcecode from
https://github.com/OpenRCT2/OpenRCT2/archive/v0.1.2.zip
unzip
Install the required libraries
sudo apt-get install cmake libsdl2-dev libicu-dev pkg-config libjansson-dev libspeex-dev libspeexdsp-dev libcurl4-openssl-dev libcrypto++-dev libfontconfig1-dev libfreetype6-dev libpng-dev libssl-dev libzip-dev -y
cd OpenRCT2-0.1.2
mkdir build
cd build
cmake ../ -DCMAKE_BUILD_TYPE=Release -DCMAKE_CXX_FLAGS="-Ofast -DNDEBUG -mcpu=cortex-a53"
make
when compilation finished (takes about 20 minutes)
make g2
copy g2 to build/data directory
To start the game cd into the build directory
./openrct2 --openrct-data-path=../data
On first run will ask for location of data files so you will need the original game cd or the demo.
Just point gui at directory the demo/game was unzipped to.
OpenRCT2 runs at 40fps with default 64mb gpu memory.
Also try Preferences>RaspberryPiConfiguration>SetResolution
and set to 800x600 or 1024x768.
For further guidance :-
https://openrct2.org/
https://github.com/OpenRCT2/OpenRCT2#3- ... g-the-game
https://github.com/OpenRCT2/OpenRCT2/wi ... 2-on-Linux
https://www.reddit.com/r/rct/comments/8 ... rry_pi_3b/
Spootin234
Re: RollerCoaster Tycoon2 with OpenRCT2 on Raspberry Pi 3b+
Thu Mar 07, 2019 10:51 am
This is absolutely amazing. But alas I am quite stupid, do you know if anyone has made a YouTube video on how to put rct2 on a pi?
leifdaniel
Sat Jul 13, 2019 5:39 am
I am getting the following error:
An RCT2 install directory must be specified! Please edit "game_path" in /home/pi/.config/OpenRCT2/config.ini.
Do I need a CD to play this on Raspberry Pi?
Return to “Gaming”
