TeddyIP
Import "filename" to another project
Sun Jul 29, 2018 12:15 pm
Hello friends,
so far I have been fairly successful import <filename>. Sometimes I find that I have declared/created a variable with very similar name/s. How do I add a function/class that will recognize the name has already been used within a code?
scotty101
Re: Import "filename" to another project
Mon Jul 30, 2018 9:14 am
The variable conflict is why using "import <filename>" alone is a bad idea. Variables on the global namespace will just overwrite each other.
A better method is to do something like this
import <filename> as <someabbreviationoffilename>
e.g.
import tkinter as tk
Then variables/functions from that file will need to have the correct namespace before they can be used.
root = tk.Tk()
It is difficult to make a more detailed recommendation without seeing your code, but it is generally a bad idea for you to have these variable conflicts in the first place. When you import a module, it (generally) shouldn't contain global variables, just functions or classes.
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Paeryn
Mon Jul 30, 2018 12:21 pm
e.g.
root = tk.Tk()
Erm, not sure what you are thinking here... The only difference between import tkinter and import tkinter as tk is that the local name bound to the module for the former will be called tkinter and for the latter will be called tk. In both cases any names declared in the module will only be in that module's namespace.
I think you are confusing this with from, e.g.
from tkinter import *
which would bind local names to each of the module's module-level names.
She who travels light — forgot something.
scotty101
Mon Jul 30, 2018 1:23 pm
You are correct. Monday morning brain!
Paeryn
Tue Jul 31, 2018 2:05 am
Thought it was a strange mistake you made. I usually have those moments in the early hours.
To the OP, I don't think there is a way for Python to let you know when a name is already in use short of checking yourself if the name is in either the dictionaries returned by globals() or locals() first. If you can give a concrete example that is causing you problems we can try to point you in the right direction.
TeddyIP
Tue Jul 31, 2018 10:14 am
Thanks all,
I have been thinking about the problem over the last couple of days. After taking on board your responses, I am trending towards what the variable returns after it exits. A I simplified breakdown as follows.
True/False will return 1, or 0 // possible conflict other variables are equal.
string will return // string + True/False
pins change state // sounds like a bad idea
Add delay // if variable hasn't been read/write in timeframe (ms)
add elif statement //
Return to “Python”
