WalterHeisenberg
PI4J + Adafruit LCD with MCP23017
Sun Jul 29, 2018 6:18 am
Trying to work with LCD but looks like Im doing something wrong.
        LCD lcd = new I2CLcdDisplay(2, 16, 1, 20,
                0, 15, 14, 13, 9, 6, 11, 12);
        lcd.clear();
Got values from python example:
# Char LCD plate GPIO numbers.
LCD_PLATE_RS            = 15
LCD_PLATE_RW            = 14
LCD_PLATE_EN            = 13
LCD_PLATE_D4            = 12
LCD_PLATE_D5            = 11
LCD_PLATE_D6            = 10
LCD_PLATE_D7            = 9
LCD_PLATE_RED           = 6
LCD_PLATE_GREEN         = 7
LCD_PLATE_BLUE          = 8
Result:
java.io.IOException: Input/output error
at java.io.RandomAccessFile.write0(Native Method) ~[na:1.8.0_65]
at java.io.RandomAccessFile.write(RandomAccessFile.java:489) ~[na:1.8.0_65]
at java.io.RandomAccessFile.writeByte(RandomAccessFile.java:991) ~[na:1.8.0_65]
at com.pi4j.io.i2c.impl.I2CBusImpl.lambda$writeByteDirect$4(I2CBusImpl.java:170) ~[pi4j-core-1.2-SNAPSHOT.jar!/:na]
at com.pi4j.io.i2c.impl.I2CBusImpl.runBusLockedDeviceAction(I2CBusImpl.java:260) ~[pi4j-core-1.2-SNAPSHOT.jar!/:na]
at com.pi4j.io.i2c.impl.I2CBusImpl.writeByteDirect(I2CBusImpl.java:169) ~[pi4j-core-1.2-SNAPSHOT.jar!/:na]
at com.pi4j.io.i2c.impl.I2CDeviceImpl.write(I2CDeviceImpl.java:92) ~[pi4j-core-1.2-SNAPSHOT.jar!/:na]
at com.pi4j.component.lcd.impl.I2CLcdDisplay.write(I2CLcdDisplay.java:280) ~[pi4j-device-1.1.jar!/:na]
at com.pi4j.component.lcd.impl.I2CLcdDisplay.lcd_byte(I2CLcdDisplay.java:188) ~[pi4j-device-1.1.jar!/:na]
at com.pi4j.component.lcd.impl.I2CLcdDisplay.init(I2CLcdDisplay.java:216) ~[pi4j-device-1.1.jar!/:na]
at com.pi4j.component.lcd.impl.I2CLcdDisplay.<init>(I2CLcdDisplay.java:133) ~[pi4j-device-1.1.jar!/:na]
at display.Display.test(Display.java:22) ~[classes!/:na]
i2cdetect -y 1
0 1 2 3 4 5 6 7 8 9 a b c d e f
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: 20 -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
What are correct values for init?
Re: PI4J + Adafruit LCD with MCP23017
Sun Jul 29, 2018 11:16 am
Can you post your Display.java source code (in [code][/code] tags) or tell us where you found it?
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
WalterHeisenberg
Sun Jul 29, 2018 2:42 pm
See first code block in my post.
Line 22 from stacktrace is the first line
LCD lcd = new I2CLcdDisplay(2, 16, 1, 20,   0, 15, 14, 13, 9, 6, 11, 12);
Sun Jul 29, 2018 4:49 pm
I need the whole Pi4J Java program because my crystal ball went offine in "The Great Crystal Ball Disaster" of 1989 and I can't invent Java at will now.
Or do I start hacking https://raw.githubusercontent.com/Pi4J/ ... ample.java ?
MQTT Evangelist
WalterHeisenberg
Sun Jul 29, 2018 5:54 pm
What are you talking about?
This is whole java program. "public static void main" + 2 lines I provided. What else do you need? Sources of pi4j?
Sun Jul 29, 2018 6:05 pm
I need something that tells me what the heck you're trying to compile and run on your Rpi because I'm not psychic and you've not given the whole picture.
http://www.catb.org/esr/faqs/smart-questions.html
If you can't do that, I can't be bothered to help. Best of luck getting your code to work.
MQTT Evangelist
WalterHeisenberg
Sun Jul 29, 2018 6:10 pm
Result:
If you can't help then just move away.
WalterHeisenberg
Sun Jul 29, 2018 6:16 pm
Your example https://raw.githubusercontent.com/Pi4J/ ... ample.java is not working for me.
I got just a message
<--Pi4J--> Wiring Pi LCD test program
in output and nothing else. Lcd didnt change the state.
WalterHeisenberg
Mon Jul 30, 2018 2:11 am
Looks like I found the issue.
was:
now:
LCD lcd = new I2CLcdDisplay(2, 16, 1, 0x20, 0, 15, 14, 13, 9, 10, 11, 12);
Trying to print something with no reaction..
        lcd.clear();
        lcd.write(0, "111 ");
        lcd.write(1, "222");
Update 1:
I feel like Im doing something wrong with GPIO connections...
Update 2:
No... python example is working fine...
Return to “Java”
Who is online
Users browsing this forum: No registered users and 5 guests
