br33d
PXE boot before microSD
Thu Jul 26, 2018 10:32 pm
I realize this has been asked before in a different form, but I couldn't quite follow the discussion.
Is there a way to make the board try to boot from PXE before it boots from the microSD?
I have a cluster of remote raspberry pis, and i'd like to occasionally reinstall them using PXE.
Specifically, I would like the pis to always try to boot using PXE, but if that fails, I would like them to fallback to booting with microSD. Thus, if I want to reinstall a pi, I configure the PXE server to respond to the MAC of that card with an new install image and use PoE to turn the card off and back on.
I see some discussion about enabling boot modes, but I don't see a description of how to change the boot order.
Is it possible to make a pi tried to boot using PXE before it tries the microSD?
thanx
ben
Re: PXE boot before microSD
Fri Jul 27, 2018 6:55 am
thanx
ben
https://www.raspberrypi.org/documentati ... /README.md
RPi 4B 4GB (SSD Boot)..
mikerr
Fri Jul 27, 2018 7:59 am
I don't think you can directly change the boot order,
but you can selectively disable SD via GPIO:
https://www.raspberrypi.org/documentati ... ootflow.md
1. E.g hold gpio22 low and SD boot will be ignored, so would boot to PXE
2. Alternatively via software: renaming /boot/bootcode.bin (which can be done on the pi itself) would also make it failover into pxe at next boot.
br33d
Sun Jul 29, 2018 12:49 pm
Yes, I had read that before posting. From that doc the answer seems to be that you cannot control boot order. The closest you can get is to use hardware pins to enable/disable different boot options, but even then the boot order remains the same, it's just that disabled options will be skipped. Or did I miss something?
br33d
Sun Jul 29, 2018 1:09 pm
I would like to go the software route. I've been thinking along the lines of your second suggestion. I was thinking that I would always PXE boot (never have the bootcode.bin on the microSD, but then have the TFTP server either serve back a cmdline.txt that makes it boot from the network or boot from the microSD. Is there a nicer way floating around?
hippy
Sun Jul 29, 2018 4:07 pm
Expanding on mikerr's suggestion earlier, by enabling GPIO selection of what to boot from it should be possible to add a microcontroller supervisor which can disable SD Card booting and enable PXE booting at initial power-on.
If PXE booting is not indicated as successful to the supervisor that can reset the Pi, enable SD Card booting, and let it out of reset for a second attempt at booting.
Such a supervisor program should be fairly straight forward so cheap and easy to implement even with no past microcontroller experience.
br33d
Sun Jul 29, 2018 11:42 pm
i'm building a cluster of almost 100 pis, so the additional hardware and wiring really isn't practical. the software solution should work fine. do you see a problem with it?
hippy
Mon Jul 30, 2018 10:18 am
Only that it always needs PXE available to boot, and the original requirement was for when PXE boot was not available.
If you always PXE boot and the system can handle all Pi's PXE booting then there should be no issue.
If you need to PXE boot and that's not available; then you have a problem.
Return to “Advanced users”
