I have use a RS485(UART) to USB to connect on my PC, I can received message from PC correctly, but when I send message from PC to RPi, RPi received message garbled.
Setup:
Raspberry Pi Zero W
2018-04-18-raspbian-stretch
Connected via USB with Xshell 6 for managment
/boot/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
dtoverlay=pi3-disable-bt
dtoverlay=pi3-miniuart-bt
# Additional overlays and parameters are documented /boot/overlays/README
dtparam=audio=on
enable_uart=1
core_freq=250
#force_turbo=1
#dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=4515e8b5-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles
dwc_otg.lpm_enable=0 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
picture of my issue
I don't know what can I fix this, I follow
https://www.raspberrypi.org/documentati ... on/uart.md
and
https://openenergymonitor.org/forum-arc ... 12311.html
but still now working...
Any ideas, has anyone been through this?
Regards,
Tina
