My RPi has gotten to really high temps (ie: 70.9c) and I don't really want to buy a fan, so I tried using pencil lead (0.7) to cool it down b/c it is a good heat conductor. It managed to cool it only by 1c.
Is this a good idea?
1C is not enough. You need 11C to avoid it throttling with the latest Raspbian.
Clocking, voltages and thermals
The improved power integrity of the BCM2837B0 package, and the improved regulation accuracy of our new MaxLinear MxL7704 power management IC, have allowed us to tune our clocking and voltage rules for both better peak performance and longer-duration sustained performance.
Below 70°C, we use the improvements to increase the core frequency to 1.4GHz. Above 70°C, we drop to 1.2GHz, and use the improvements to decrease the core voltage, increasing the period of time before we reach our 80°C thermal throttle; the reduction in power consumption is such that many use cases will never reach the throttle. Like a modern smartphone, we treat the thermal mass of the device as a resource, to be spent carefully with the goal of optimising user experience.
