What happened to fstrim ?
Fri Nov 02, 2012 2:05 pm
Previously I have issued the command "sudo fstrim -v /" and it went away for a while eventually coming back announcing how many blocks it had freed.
Since doing some "apt-get update; apt-get upgrade" recently it returns with an error "fstrim: /: FITRIM ioctl failed: Operation not supported".
What happened?
Now, I'm not even sure fstrim can do anything for SD Cards as the have no TRIM command. I had hoped that maybe fstrim uses their ERASE command instead.
Is fstrim supposed to work for SD Cards? Has it changed recently? Or has my system changed somehow?
Return to “Raspberry Pi OS”
