tiancaipipi110
3D character in Raspberry Pi using Blender, feasible?
Tue Jul 17, 2018 7:51 pm
Can I build 3D characters/animations with Blender(or any other supported modeling software) and deploy and run in Raspberry Pi ? I know there're some hardware limitations, not sure if there's a workaround. Thanks in advance.
Gavinmc42
Re: 3D character in Raspberry Pi using Blender, feasible?
Wed Jul 18, 2018 3:07 am
Yes you can and there is not even much work around needed any more ;)
viewtopic.php?f=68&t=214695
If you know Blender, use it, if you tried and failed to learn it, try BforArtists.
This is pretty much new stuff, pushing the VC4 GPU to the max ;)
The main trick seems to be taking the obj files and parsing them into a form the VC4 can handle.
We are all waiting to see Tim's code for the "ah, hah, that's how you do it" moment :D
I'm dancing on Rainbows.
Imperf3kt
Wed Jul 18, 2018 8:44 am
I'm not sure if Blender runs on a Pi too well.
I use it on my old desktop PC which has severalfold more CPU and GPU power, as well as 8GB of RAM, and it takes up a lot of system resources, just siting the program at idle.
55:55:44:44:4C
52:4C:52:42:41
tiancaipipi110
Wed Jul 18, 2018 2:36 pm
Nice. Thanks for the info:)
Gavinmc42
Thu Jul 19, 2018 1:27 am
Blander and BforArtisits use OpenGL in their UI.
Any improvement in that improves the Blender experience.
viewtopic.php?f=66&t=216804
Aarch64 OS's won't run faster due to Pi's using only 32bit DDR memory, but stuff in cache and b4a lite verson compiled specifically for Aarch64 does seem to make a BIG difference :D
I don't have a Gentoo32 bit OS to compare it for real, but Sakaki does have a way to run 32bit code on Gentoo64.
viewtopic.php?f=54&t=211260
So you could test the Raspbian Blender on Gentoo64.
The VC4 V3D driver is being worked on by Eric Anholt, I already feel it is stable enough for testing and even learning mesa3d coding.
If I knew lots more about Gentoo64 I feel I could even use it as a decent Desktop.
A the moment I play and break it weekly as I learn Gentoo's way of doing things.
Just yesterday I learned Sakaki has a page of kernels, followed the instructions and upgraded from 4.14.44 to 4.14.54 in minutes :o
https://github.com/sakaki-/bcmrpi3-kernel/releases
It takes much longer in Raspbian to do that.
Imperf3kt
Thu Jul 19, 2018 2:45 am
My concerns actually lied with the amount of RAM available. 1GB (less what the system needs) is not really enough for editing 3D things beyond the simple stuff.
55:55:44:44:4C
52:4C:52:42:41
Gavinmc42
Thu Jul 19, 2018 3:58 am
Never really noticed Gentoo64 running out of memory when looking at Tim's starship model in b4a, about 10% usage.
Some tricks people have tried is zram, ie compression turns 1GB into about 1.5GB?
Eric's OpenGL driver only needs min 16MB and assigns more as needed.
I had a real reason to go to Gentoo64, more registers and faster access to the NEON, which I think happens when GCC 7.3 compiles b4a on Aarch64. Can it be tweaked even more?
Mesa3d libs/examples compile fine on Gentoo64, more deps needed in Raspbian.
Have not got around to bench marking the mesa3d code.
How far can a Pi be pushed for 3D modeling, no idea, this is all new to me.
To do Tim's texture baking with fog and lighting probably going to something bigger than a Pi?
But Tim has proved displaying it on a Pi even a Zero is not a problem.
Simple 3D modeling yes, making a Blender movie? Who knows, let's find out :D
A Pi Blender render farm? A stack of Pi3B+ could do it?
If one Pi can only render at 1fps, 24 Pi's will make it real time?
1GB is not a small amount of memory, if used well ;)
Gavinmc42
Fri Jul 20, 2018 12:12 pm
