I have the Raspbian image (the latest prior to the 512Mb update). I've been running the Pi fine for a while but never more than for a few hours. I have been trying to get a particular project running (temperature logging via an Arex tl-500) but run into a problem. The Pi would randomly freeze - just drop off the network and only be recoverable by a reboot. This was both on wired and a wireless USB dongle. Now it won't start the network at all. Having plugged it into the TV to get an HDMI console, I can see it is booting but I get an error on the dwc_otg module (it scrolls too fast to catch) and the network fails to initialise. The Pi is unresponsive to the USB keyboard. I then somewhat foolishly tried my new 512Mb Pi. That shortly went the same way. Before the first one failed I was unable to see the peripheral (the TL-500) attached to the USB with lsusb - it had disappeared.
I noticed that the USB connectors did get rather warm (I'm running the Pi from a powered USB hub)
I don't have any console access via serial so cannot investigate further. I have tried several different card images with no joy.
So I now have two Pi that are useless as they cannot communicate with anything. This was a bog standard off the shelf USB powered hub. No other mods.
Any hints on getting things up and running?
Or is the Pi really this fragile and really not fit for use as a general purpose computer but needs to be wrapped in cotton wool? I'm really keen on the Pi and this is a real frustration.
