rajdes
how to use boto
Sat Jul 14, 2018 2:15 pm
How to use boto
How to upload multiple images from folder to aws at same time can store all your images in one particular folder and then use this kind of python script to upload all images found in your folder :
But the problem is it does not work.....help plz
import os
import boto3
s3 = boto3.resource('s3')
directory_in_str="E:\\rekog\\hold"   # change directory path to your images folder
directory = os.fsencode(directory_in_str)
for file in os.listdir(directory):
    filename = os.fsdecode(file)
    if filename.endswith(".jpeg") or filename.endswith(".jpg") or filename.endswith(".png"):
        strg=directory_in_str+'\\'+filename
        print(strg)
        file = open(strg,'rb')
        object = s3.Object('bucketname',filename)
        object.put(Body=file,ContentType='image/jpeg')
    else:
        continue
B.Goode
Re: boto
Sat Jul 14, 2018 8:40 pm
Nor does my crystal ball!
But...
Does that mean you are running this script on a Microsoft Windows system?
rajdes
Re: how to use boto
Sun Jul 15, 2018 3:27 am
Yes I'm test running the code before runningi it on pi
The Traveler
Re: how to use boto
Sun Jul 15, 2018 4:27 am
Error output or log?
If you're going to copy and paste code written by someone else, you should at least provide the error log output so others can fix it for you.
Retired IT professional, C programmer and "beardie weirdie".
RPi interests: Developing an Infinite Improbability Drive
“Thinking outside of the box allows you to get rewards outside of your reach.” Matshona Dhliwayo
rajdes
Re: how to use boto
Mon Jul 16, 2018 2:12 pm
For being true I'm immature I have no idea about coding in python I'm looking at scripts and tryingt to figure out..without any proper resources..if anyone is interested to help please I would b grateful of u all..
The Traveler
Re: how to use boto
Mon Jul 16, 2018 2:36 pm
Start here: https://www.python.org/about/gettingstarted/ and learn the basics at least. There are a huge number of tutorials and information resources on the Internet for you to use. Asking for someone to solve your problem for you teaches you nothing otherwise.
B.Goode
Re: how to use boto
Mon Jul 16, 2018 3:32 pm
https://www.raspberrypi.org/magpi/learn ... ng-python/
https://www.raspberrypi.org/magpi/best- ... ogramming/
https://www.raspberrypi.org/documentati ... /README.md
https://projects.raspberrypi.org/en/pro ... 5B%5D=%201
Return to “Python”
