Hi, I just got a Raspberry Pi 3 B+ (I also own a Pi 3) and I am having problems connecting to it using OpenVPN from an external IP address.
I'm not to well up on how to configure it but I used the installer from https://install.pivpn.io.
Swapping hardware over to the old Raspberry Pi 3 everything works fine, even from External IP address, the problem is the NEW PI 3 B+.
When I switch over to the new Pi 3 B+ it doesn't connect, so I edited the .ovpn file to connect to it via LOCAL IP address and it works fine.
Something is blocking the connection in the new Pi 3 B+ setup via external IP, anyone one know what it could be ?
