NeilMedHat
Screen Black after Firmware update
Fri Jul 13, 2018 7:04 pm
New problem, can no longer get a screen after the rainbow, I did some editing on the config file as what I searched "hdmi_drive=1
hdmi_force_hotplug=1" I get some text now as loading then no signal message from monitor :(
Thanks!
HawaiianPi
Re: Screen Black after Firmware update
Sat Jul 14, 2018 3:00 am
If you have SSH enabled you can login via SSH, edit /boot/config.txt and reboot.
If you have a keyboard attached to the Pi you can try a blind login and shutdown after hitting Control+Alt+F2 to open a CLI (or just Alt+F2 from Raspbian Lite with no GUI).
Otherwise, pull the power, hope you don't corrupt anything, and edit the file on your main PC.
klricks
Sat Jul 14, 2018 3:39 am
Thanks!
Explain what you mean by firmware update and how you did that and why?... Simple edits to a config file is not a firmware update.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
NeilMedHat
Sat Jul 14, 2018 6:29 pm
I used this vid. Think quicker and safer to start over.
https://youtu.be/a7X36jheRS8
Sat Jul 14, 2018 6:32 pm
Good idea using a video from FIVE YEARS ago, that's going to still work, not.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Return to “Beginners”
