I'm totally new to raspberry pi. So I have my first problem ..
I flashed my Micro SD card with Etcher (OS: Raspian Stretch)
I connected a mouse, keyboard and my HDMI television but I got the message: "NOT SUPPORT"
my TV:
Screen Size: 32"
Resolution: 1366 x 768 (WCGA)
Aspect Ration: 16:9
HDMI: yes
My CONFIG.TXT
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1366
#framebuffer_height=768
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=86
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=5
# uncomment for composite PAL
sdtv_mode=2
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
Can anyone help me with the setup so I can start learning ??
