Eboy
Pixel For Pc
Wed Jul 11, 2018 7:24 pm
I turned an old laptop to run PIXEL and Ethernet works, but wifi does not. I can't find the solution.
Re: Pixel For Pc
Wed Jul 11, 2018 9:10 pm
If you are using something called Pixel you are probably using a VERY old version since that name has not been used for over a year.
Download the latest version of Raspbian Desktop for x86 and use that. Wifi should work I beleive.
Re: Pixel For Pc
Wed Jul 11, 2018 10:47 pm
Download the most recent x86 Debian Stretch with RPD:
https://www.raspberrypi.org/downloads/r ... i-desktop/
If still not work post back with Wireless Chipset model..
adieu
My other Computer is an Asus CS10 ChromeBit
klricks
Re: Pixel For Pc
Wed Jul 11, 2018 11:32 pm
There can be many causes. Here is one thing to check:
The built in WIFI in the laptop might be old standard 802.11g. If so make sure that the WIFI router is also set to 802.11g -OR- mixed mode 802.11 g and n.
It is also possible that the laptop WIFI is the even older 802.11b which newer router might not support at all.
My router is set to 802.11n only and I don't want to change it, so I disabled the built in WIFI (b & g only) in my laptop and use a USB WIFI dongle which supports the much faster 802.11n standard.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
mikerr
Re: Pixel For Pc
Thu Jul 12, 2018 7:44 am
While you should really just download the latest version,
running an update:
sudo apt-get update && sudo apt-get dist-upgrade
will have the same effect and bring in the most recent drivers for WiFi etc.
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 6:21 pm
running an update:
Thanks I will try that!
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 6:24 pm
Thanks!
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 6:28 pm
Sure thing
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 6:30 pm
I will check
bensimmo
Re: Pixel For Pc
Thu Jul 12, 2018 7:15 pm
What laptop is it? Make & model
That can then be searched by people to find you WiFi chipsets.
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 7:46 pm
It is an Acer aspire r3
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 8:26 pm
The update didn't work by itself is there anything I have to after the update?
klricks
Re: Pixel For Pc
Thu Jul 12, 2018 9:40 pm
Need complete model number..... there are too many variants.
Eboy
Re: Pixel For Pc
Thu Jul 12, 2018 9:47 pm
N15W5
Re: Pixel For Pc
Fri Jul 13, 2018 2:15 am
N15W5
The manufacturer and model number is needed for the Wireless Chipset, see if it is recognised by hardinfo software:
https://www.google.co.uk/amp/s/www.tech ... linux/amp/
adieu
Eboy
Re: Pixel For Pc
Sat Jul 21, 2018 12:59 am
N15W5
I can't get it to download
Eboy
Re: Pixel For Pc
Sat Jul 21, 2018 1:04 am
Sorry I meant Raspbian desktop. Will the update do the same?
Eboy
Re: Pixel For Pc
Sat Jul 21, 2018 1:13 am
Ok so I checked I do have the latest version but wifi is still not working
Re: Pixel For Pc
Sat Jul 21, 2018 6:26 am
The latest June 2018 x86 Operating System is ' Debian Stretch with Raspberry Pi Desktop'
Many Laptops have either a switch or key combination to enable / disable WiFi have you checked that it is enabled ?
Regards finding out what hardware is in your Laptop you need an internet connection and install hardinfo:
sudo apt update
sudo apt install hardinfo
https://packages.debian.org/stretch/hardinfo
adieu
Eboy
Re: Pixel For Pc
Mon Aug 13, 2018 6:42 pm
K would it be possible to use a Linux compatible USB wifi dongle? Thanks for the responses!
Re: Pixel For Pc
Mon Aug 13, 2018 6:52 pm
Yes.......
adieu
Return to “Raspberry Pi Desktop for PC and Mac”
