thejasonballinger
GPIO LED not Working
Wed Jul 11, 2018 5:19 pm
I am using a LED on my Raspberry Pi 3. I am trying to simply get it to toggle because it is not working properly. I have tried different pins and different resistance strengths, but I cannot get it to work at all. I believe it is a hardware issue so if anybody can help me with that that would be great. However, I want to give you my code in case it is a software issue.
Please keep in mind that I am on the latest version of Python 3 (Python 3.5.3).
Here is my code:
from gpiozero import LED
from time import sleep
led = LED(26)
while True:
	led.toggle()
	sleep(1)
Please get back to me as soon as possible, I need this for a project that I am working on.
Thanks!
DirkS
Re: GPIO LED not Working
Wed Jul 11, 2018 5:24 pm
Did you connect the LED the right way around?
Did you connect the LED to the correct pin? gpiozero uses BCM numbering by default, so GPIO26 is on physical pin 37 (see https://pinout.xyz/pinout/pin37_gpio26)
rpiMike
Wed Jul 11, 2018 5:30 pm
Post a photo of your wiring.
thejasonballinger
Wed Jul 11, 2018 5:36 pm
Here's a link to the pictures: [url]https://photos.app.goo.gl/FYD7qChhRnqPoMjy8[url]
thejasonballinger
Wed Jul 11, 2018 5:37 pm
Oops, here: https://photos.app.goo.gl/FYD7qChhRnqPoMjy8
DirkS
Wed Jul 11, 2018 5:42 pm
Blacking out most of the images doesn't make it any clearer...
Doesn't really seem to be any need to do that, I can see you have a Pitop anyway ;)
rpiMike
Wed Jul 11, 2018 6:59 pm
Can't tell from your photos how its wired. That led looks huge - what specification is it.
Z80 Refugee
Wed Jul 11, 2018 9:57 pm
It's easy to find out whether the LED works: connect it (with resistor) between the 3.3V and 0V on the GPIO. It should then light up. If it doesn't light up, there is no way it will light up when you connect it to a GPIO output. Simples.
Beginners Guide to Wiring Things to the GPIO
Military and Automotive Electronics Design Engineer (retired)
For the best service: make your thread title properly descriptive, and put all relevant details in the first post (including links - don't make us search)!
thejasonballinger
Thu Jul 12, 2018 4:39 pm
ok. thank you for the link.
Z80 Refugee
Thu Jul 12, 2018 5:23 pm
It's just an ordinary LED in an 8 or 10mm package. Nothing to worry about (probably). The resistor might be 330 ohms, not too clear. Dunno how the switches are wired up though!
Return to “Python”
