Pietro_il_magnifico
Power through 5v GPIO
Mon Jul 09, 2018 6:46 am
Hello everyone,
i have a question related to power supply. Can i draw power through 5v GPIO? I saw the raspberry pi 3 model b+ schematics (https://www.raspberrypi.org/documentati ... educed.pdf) but i can't find a real motivation of why i cannot.
P.S. i tried to power up through GPIO but i had a lot of problems like: card reader not working and after few days i tried on another raspberry with the same power supply method and i had SD card corrupted
joan
Re: Power through 5v GPIO
Mon Jul 09, 2018 7:11 am
All the Pi GPIO are 3V3. If you feed 5V into a Pi GPIO you are likely to destroy the GPIO and the Pi.
You can power by supplying 5V to a 5V pin on the expansion header (i.e. supply power to the 5V rail and ground).
HawaiianPi
Mon Jul 09, 2018 7:16 am
Yes, you can power a Pi through the GPIO header +5V DC and Ground pins.
Your troubles were likely caused by a poor or inadequate power supply.
piglet
Mon Jul 09, 2018 8:09 am
However doing that you will bypass the polyfuse that gives you a certain amount of protection.
