Spongy
How can i open my RaspberryPi Configs in VNC Desktop?
Sat Jul 07, 2018 3:52 pm
I have a problem with my VNC desktop.
I cant open my configs in the VNC desktop.
In the console is this error:
Client is not authorized to connect to Server
(rc_gui:1361): Gtk-WARNING **: cannot open display: :1.0
Please help me. :cry:
topguy
Re: How can i open my RaspberryPi Configs in VNC Desktop?
Sun Jul 08, 2018 11:30 am
What "configs" ?
What console ?
Show us exact command and error.
DirkS
Sun Jul 08, 2018 1:30 pm
Open them from the menu...
LTolledo
Sun Jul 08, 2018 10:04 pm
What VNC you are using?
Lack of full information of the system where the fault originated deters us from giving meaningful response....
none of us have crystal ball nor having ESP abilities....
Some people be like:
petitnj
Thu Sep 12, 2019 9:23 pm
Running latest Buster
From the VNC (tightvnc) window the pull down menu
Preferences>Raspberry Pi Configuration
Does nothing.
That menu item calls rc_gui
Which responds with
"Client is not authorized to connect to server"
Before Buster this worked. Now on the latest Buster it quits with no message.
petitnj
Thu Sep 12, 2019 9:52 pm
Found the answer. When a menu item launches a application, it has to keep the original environment and use SUDO_ASKPASS environment to see if this user is authorized as a super user.
The menu command default is
env SUDO_ASKPASS=/usr/bin/rc-gui/pwdrcg.sh sudo -A rc_gui
(note the different rc-gui and rc_gui). Unfortunately, that forgets the environment and doesn't know who is calling the program. Thus rc_gui cannot authorize the user to change the menu and it just crashes.
Go to the Preferences>Main Menu Editor
and change the command for Raspberry Pi Configuration properties to make it
env SUDO_ASKPASS=/usr/bin/rc-gui/pwdrcg.sh sudo -AE rc_gui
Adding the E keeps the environment (and remembers you are the authorized "pi") user.
Hopefully, this bug will be fixed with later editions of Buster
mattmiller
Fri Sep 13, 2019 6:46 am
Using the built in RealVNC server on my Pi4 and using RealVNC viewer from a Win 10 machine - it works fine for me
Fri Sep 13, 2019 6:56 am
This appears, as in other posts, one either uses the supported on the Raspberry Pi SBC RealVNC, or uses a 'one size fits all' software which may or may not function as expected.
I vote for RealVNC every time......
RPi 4B 4GB (SSD Boot)..
LTolledo
Sat Sep 14, 2019 1:21 am
fruitoftheloom wrote:I vote for RealVNC every time......
+1
definitely!
absolutely!
nothing compares....
"...resistance is futile....."
Return to “Raspberry Pi OS”
