aBUGSworstnightmare
Re: Multiple Frame buffer beta testers wanted
Wed Oct 17, 2018 2:43 pm
Hi jamesh,
will test them and let you know. Should now be able for intense testing of second frame buffer for displays connected to DPI (as my first boards showed a production issue on the connector and I had to order new ones).
Target is to test combinations listed below:
- HDMI only
- DPI only
- DSI only
- HDMI + DSI
- HDMI + DPI
on a CM3L based solution. Don't care about composite video (and don't have HW to test it), so I will leave this to sombody else.
I have a good lineup on displays on hands and want to test if I will hit a max performance wall at some point (i.e. with 2 FHD displays connected, both at 60Hz frame frequency, and one or both of them rotated)
If this works I might look into driving one half of a 4k2k displays = 2 times 980x2160pixels with a single Pi - just for the fun of it :lol:
wilsonb
Wed Oct 17, 2018 6:10 pm
jamesh wrote:
Wed Oct 17, 2018 2:15 pm
aBUGSworstnightmare wrote:
Mon Oct 15, 2018 7:41 am
Hi jamesh,
did any of the multiple framebuffer code made it into latest Raspbian release (2018-10-09)? If not, can you prepare files to test with latest version?
OK, have the images built, and put them here
https://drive.google.com/open?id=1Q5TQ1 ... 4UMavmTh7H
I think they work OK, haven't done a lot of testing, just merged to latest masters and rebuilt, with a very quick test to make sure framebuffer actually appeared.
This is 4.14.76, so slightly newer than the current release, so might be a modules mismatch.
Hi thanks for all the effort. I have replaced kernel and start with the ones you provided. At this point, what else would need to be done to get them both working? Asking because there are a lot of message here to go through and not sure if there are new instructions. Maybe we should make a 'sticky' on first page.
Im using RetroPie and using the new Pimiero HyperPixel 4.0 https://shop.pimoroni.com/products/hype ... 9485443155
and after replacing files with HDMI plugged in, LCD looks good but HDMI is blank no rainbow.
Wed Oct 17, 2018 8:21 pm
Hi jamesh,
Enable the camera using raspi-config to make it uses the correct start_x.elf
aBUGSworstnightmare
Thu Oct 18, 2018 5:28 am
Hi, as this is beta testing you should use Raspbian OS for testing with. Other versions (i.e. OSMC, Retropie, ..) might cause unknown issues as they - quite often. - use their own kernel.
Here is a brief guideline how to start (hope I didn't missed a point/mixed up the order):
1) prepare a fresh uSD, boot and configure (initial setting for WiFi,Keyboard, etc) using HDMI display only
2) add 'start_x=1' to config.txt
3) replace the /usr/share/X11/xorg.conf.d/99-fbturbo.conf contents with the contents below
# This is a minimal sample config file, which can be copied to
# /etc/X11/xorg.conf in order to make the Xorg server pick up
# and load xf86-video-fbturbo driver installed in the system.
# When troubleshooting, check /var/log/Xorg.0.log for the debugging
# output and error messages.
# Run "man fbturbo" to get additional information about the extra
# configuration options for tuning the driver.
#Section "Device"
#        Identifier      "Allwinner A10/A13 FBDEV"
#        Driver          "fbturbo"
#        Option          "fbdev" "/dev/fb1"
#        Option          "SwapbuffersWait" "true"
#EndSection
Section "Device"
        Identifier      "fbturbo0"
        Driver          "fbturbo"
        Option          "fbdev" "/dev/fb0"
        Option          "debug" "true"
EndSection
Section "Device"
        Identifier      "fbturbo1"
        Driver          "fbturbo"
EndSection
Section "Device"
        Identifier      "fbdev0"
        Driver          "fbdev"
EndSection
Section "Device"
        Identifier      "fbdev1"
        Driver          "fbdev"
EndSection
Section "Monitor"
    Identifier "Monitor0"
    Option "Primary" "False"
EndSection
Section "Monitor"
    Identifier "Monitor1"
    Option "RightOf" "Monitor0"
EndSection
Section "Screen"
    Identifier "ScreenTurbo0"
    Monitor "Monitor0"
    Device "fbturbo0"
    Subsection "Display"
    EndSubSection
EndSection
Section "Screen"
    Identifier "ScreenTurbo1"
    Monitor "Monitor1"
    Device "fbturbo1"
    EndSubSection
EndSection
Section "Screen"
    Identifier "ScreenDev0"
    Monitor "Monitor0"
    Device "fbdev0"
    EndSubSection
EndSection
Section "Screen"
    Identifier "ScreenDev1"
    Monitor "Monitor1"
    Device "fbdev1"
    EndSubSection
EndSection
Section "ServerLayout"
    Identifier "Multihead"
    Screen  0 "ScreenTurbo0"
    Screen  1 "ScreenTurbo1" rightof "ScreenTurbo0"
    Option  "Xinerama" "true"
EndSection
    Identifier "Singlehead0"
EndSection
    Identifier "Singlehead1"
    Screen  0 "ScreenTurbo1"
EndSection
Section "ServerFlags"
    Option "BlankTime"  "0"
    Option "StandbyTime"  "0"
    Option "SuspendTime"  "0"
    Option "OffTime"  "0"
    Option "DefaultServerLayout" "Singlehead0"
EndSection
4) reboot
5) copy files from here viewtopic.php?f=63&t=216399&start=200#p1381436 (latest at the time of writing the post) to uSD
6) reboot
7) use raspi-config and select to boot to CLI
8) reboot
9) at command line: start desktop with
startx -- -layout Multihead
10) check if frame buffer is created
ls /dev/fb*
11) enable and configure your second display, reboot, check if frame buffers are generated (same command as above). If everything went well you should have two displays running now. For changing desktop priority read here viewtopic.php?f=63&t=216399&start=175#p1364127
NOTE: As the HYPERPIXEL display is using DPI interface you cannot use it together with the official 7in display (because DPI and DSI can't be used together)!
aBUGSworstnightmare
Fri Oct 19, 2018 12:16 pm
Tested with a fresh installation where it did not work (lost USB devices; same as already reported earlier).
Then used an old installation. After update/upgrade/rpi-update/reboot only one framebuffer was generated. Replaced the kernel7.img and start_x.elf with your files and then got it working.
Need to say that I'm on a standard RPi 3 atm, with DSI + HDMI.
Note: I see the same issue as already reported here viewtopic.php?f=98&t=222143
Fri Oct 19, 2018 12:34 pm
That's a module mismatch. I should have rebuilt the stuff at a specific version number, however, I just used top of tree. It currently required 4.14.76 modules I believe.
Linked post seems unrelated?
aBUGSworstnightmare
Fri Oct 19, 2018 12:48 pm
jamesh wrote: That's a module mismatch. I should have rebuilt the stuff at a specific version number, however, I just used top of tree. It currently required 4.14.76 modules I believe.
Yes, I'm on 4.14.76.
Well, I'll just wanted to make a comment on the 'battery icon' as this seems to show up due to the module mismatch (as it's for sure not related to frame buffer)
GreggTheB
Fri Oct 19, 2018 10:08 pm
ABugsWorstNightmare;
Did you solve the problem with USB input seizing? I followed the latest instructions here, and am running into the same or-similar- problem. When x starts, no USB input.
aBUGSworstnightmare
Sat Oct 20, 2018 5:43 am
GreggTheB wrote: ABugsWorstNightmare;
I still need to verify this, but a fresh installation with
sudo  apt-get update && apt-get upgrade -y
sudo rpi-update
should do the trick.
Once you've done this continue with no2 of my short how-to. Should work now.
I did update/upgrade/rpi-update after I lost USB mouse and bluetooth keyboard control. Funny thing was that a freshly connected USB keyboard was detected/working, so I could inout the commands at CLI, reboot and then start - now working - x.
If you have another USB keyboard on hands you should try too.
luciodeep
Thu Oct 25, 2018 9:30 am
Hi all,
I'm new in this forum, but I'm not really new to rpi and Linux and I would like to be active part in the beta testing of this feature because I was searching for months for it.
I've followed your numbered step-by-step guide to achieve multiple framebuffers on mi Pi but I've surely a module mismatch (usb not working, wifi & BT not working - "FAILED" on initializing modules during startup); I'm on Raspbian Jessie 4.14.77 kernel version (done update && rpi-update a few days ago) and I'm using official dsi lcd and hdmi tv.
If it is possible take part to beta testing in this phase, I need some directives on how to achieve the goal of have multiple framebuffers.
will a Fresh installation do the trick or do I have to wait for official release?
Please let me know if is it available for download a Kernel7.img and start_x.elf suitable for version 4.14.77 .
By the way, if you know that or have a forecast, How many time we 've to wait for official support in Jessie for multiple framebuffers.
Thank you very much for your very appreciated work
I'll stay in touch with you here.
L.
Raspberry Pi 3 B - Raspbian Jessie + kodi Krypton w/CarPC carbon skin by idorel77 + Open auto
aBUGSworstnightmare
Thu Oct 25, 2018 10:48 am
luciodeep wrote: Please let me know if is it available for download a Kernel7.img and start_x.elf suitable for version 4.14.77 .
Have you tried to replace these two files with the ones available here? viewtopic.php?f=63&t=216399&start=200#p1381436
That's what was working for me (as written above)
luciodeep
Thu Oct 25, 2018 12:20 pm
Yes, of course, I did it :)
Replacing these two files result in :
boot with official dsi ts + hdmi (samsung 32 " hd ready tv) connected; I have splash screen on both screen, startup trace on "main" screen (framebuffer priority works like a charm)....but no usb devices (neither "old" or "fresh" devices), no wifi (so no ssh), no bt.....battery icon (empty with red edges): so no chance to try this feature and test it
Let me know if I can give you more details...
Thx :roll:
Thu Oct 25, 2018 1:48 pm
Thx :roll:
This is because the kernel modules do not match the test kernel supplied. I guess I need to rebuild to the current release kernel, rather than the top of tree. Unless rpi-update gets the right modules? Not sure.
luciodeep
Thu Oct 25, 2018 1:59 pm
I think so.
I've not tried rpi-update after replacing files. That's the overnight challenge!
aBUGSworstnightmare
Thu Oct 25, 2018 2:05 pm
I think that would be the safest way to proceed, allowing everyone to participate.
Thu Oct 25, 2018 2:15 pm
I think so.
rpi-update will overwrite the new files, so you would need to recopy them afterwards.
luciodeep
Thu Oct 25, 2018 3:24 pm
I think so.
OK.
I'll try this tonight (I live in Rome - Italy now I'm at work ;) )
I'll update you.
Thx
luciodeep
Fri Oct 26, 2018 8:39 am
I think so.
OK.
I'll update you.
Thx
Hi @jamesh ... no luck!
I've done following:
  • replaced files you provided --> update, upgrade,rpi-update --> reboot --> module mismatch (no wifi, no bt, no usb devices) --> could not check if /dev/fb1 is created --> re-copy your files --> same thing
  • replaced start_x.elf with yours but not kernel7.img --> update, upgrade,rpi-update --> reboot --> starts at cli command line, have wifi, bt, usb devices --> startx -- -layout Multihead --> success but only dsi tft shows desktop (framebuffer priority has set to dsi lcd) --> only /dev/fb0 has been created
  • tried with a fresh install of raspbian (update, upgrade, rpi-update), followed numbered steps --> another time update, upgrade, rpi-update --> reboot --> no luck! (no wifi, no bt, no usb devices)
So this is
Bye
aBUGSworstnightmare
Fri Oct 26, 2018 8:55 am
Maybe only run rpi-update and then replace the two (!) files in /boot. Test if it is workinng (without running update/upgrade!).
Hopefully I have time this weekend to resume testing. Will start with a fresh installation and keep the current uSD unchanged.
luciodeep
Sat Oct 27, 2018 1:30 am
Hi, finally got it working.
  • prepared a fresh install
  • done initial configuration
  • applied config.txt and x11 conf file modifications
  • rpi-update 0018be6 (4.14.76+)
  • copied kernel7.img and start_x.elf
  • rebooted
  • copied 99-fbturbo.conf in xorg.conf
  • testing
If you need specific tests i can help in, you'r welcome!
aBUGSworstnightmare
Mon Oct 29, 2018 5:59 am
Started testing again, this time using a CM3L Compute Module on my custom carrier board LVDS4CM3L.
Tested HMDI + DSI with no issues
HDMI + DSI testing. LCD module on 1st LVDS interface (HDMI) is HD-resolution (1366x786pixels)
Rotated the screens, changed frame buffer priority, played different videos to screens (playing at the same time) , .. all without problems (also when rotated)
HDMI + DPI is still ongoing. Will have to test a Full-HD connected to the second LVDS port (on expansion board, using DPI interface)
Nexus 7 display connected to LVDS4CM3L secondary LVDS port
both LVDS displays connected directly, without A/D-board
Need to test capability of DPI interface so see if it is possible to drive up to FHD resolution from there.
Test done so far (similar to HDMI + DSI) did not show any problem.
Note: HDMI and DSI only are working fine too!
aBUGSworstnightmare
Mon Oct 29, 2018 10:37 am
Did some more testings today.
Google Nexus 7in (1280x800 portrait mode) and 18.5in Full-HD (1920x1080; rotated to portrait) - both connected directly to LVDS4CM3L expandable baseboard
Connected the 18.5in Full-HD to the LVDS expansion board. It works just fine, even when rotated to portrait mode.
Couldn't see any issues so far.
@jamesh: is there any specific test you want me to do?
Last edited by aBUGSworstnightmare on Tue Oct 30, 2018 6:54 am, edited 1 time in total.
Mon Oct 29, 2018 10:49 am
Is this built for 4.19.0-V7+ (hexxeh commit d31aa70) yet? I've freed up my touch screen (it's no longer on my ADS-B decoder, it's going on a machine with a DVB TV μHAT - as a portable TV) so I can try testing this stuff again.
This is a doctor free zone.
Mon Oct 29, 2018 11:06 am
I've not done a build against 4.19 yet.
Mon Oct 29, 2018 11:11 am
OK. I'll rpi-update back to 4.14.78-v7+ before trying my experiments.
