Gavinmc42
ebuilding 64bit games
Tue Jun 19, 2018 5:45 am
Now that I have both my Pi3B+'s working and compiling stuff like Mesa3D, I want to try some OpenGL games.
Gaming pushes computers, I want to see how far the Pi3B+ can be pushed :D
Warzone2100, 0AD, Supertuxkart are OpenGL games but there is no Aarch64 ebuilds for lots of things like these.
In Raspbian with OpenGL turned on -
Warzone will run , some issues but playable.
0AD will start up and then stop.
Supertuxkart ? Is it too big to run on a Pi?
The other thing is the kid may then find Pi's fun and I can get my PC back from him :lol:
Supertuxkart can be networked so a multiplayer, better than arcade, racing game with Pi's become possible.
Learning how to compile games can led to modifying of games which requires some software learning ;)
Supertuxkart is good for doing that, but It may need serious pruning to get it working.
https://supertuxkart.net/Community
I'm dancing on Rainbows.
Gavinmc42
Re: ebuilding 64bit games
Tue Jul 03, 2018 2:33 am
Been doing a crash course in OpenGL/ES 3D coding.
Hand coding OpenGLES is not fun, which is why people use 3D modeling tools.
One of the best free ones is Blender, it uses OpenGL in it's UI.
Is Blender available on Gentoo64?
A google showed an Android OpenGLES version back in 2012.
I noticed the screenshot has Gimp.
So most of the pieces are on Gentoo64 for making/designing 3D models and games.
sakaki
Wed Jul 04, 2018 4:14 pm
Gavinmc42 wrote:Is Blender available on Gentoo64?
media-gfx/blender is available in the Gentoo tree, however it is not currently keyworded for arm64, as you can see by using eix:
pi64 ~ # eix --exact --verbose blender
* media-gfx/blender
     Available versions:  *2.72b-r4 ~*2.79 *2.79-r1
     IUSE (all versions): +boost +bullet collada colorio cuda cycles +dds debug doc +elbeem ffmpeg fftw +game-engine headless jack jemalloc jpeg2k libav llvm man ndof nls openal opencl +openexr openimageio openmp +opennl opensubdiv openvdb osl player redcode sdl sndfile test tiff valgrind CPU_FLAGS_X86="sse sse2" PYTHON_SINGLE_TARGET="python3_5 python3_6" PYTHON_TARGETS="python3_4 python3_5 python3_6"
     Homepage:            https://www.blender.org
     Find open bugs:      https://bugs.gentoo.org/buglist.cgi?quicksearch=media-gfx%2Fblender
     Description:         3D Creation/Animation/Publishing System
     License:             || ( GPL-2 BL )
No reason why you couldn't try building it yourself though. To do so just create the file /etc/portage/package.accept_keywords/blender and put in it:
media-gfx/blender * ~*
This will allow any version of the blender ebuild keyworded as stable (the *) or testing (the ~*) on any architecture to become a build candidate for your arm64 system (see the "Available versions:" line in the eix output above - in effect, this means the system will try to emerge v2.79-r1 if asked, as it is the most recent match under these criteria).
You'll also need to enable the theora USE flag for ffmpeg, so create the file /etc/portage/package.use/blender and put in there
# local USE flags for media-gfx/blender, e.g. (uncomment following line to set):
# media-gfx/blender opencl
# dependency USE flags for media-gfx/blender
media-video/ffmpeg theora
You should then be able to:
pi64 ~ # emerge --ask --verbose media-gfx/blender
It may take a while to build ^-^
best, sakaki
PS firefox-61.0 is now available on the binhost!
Gavinmc42
Thu Jul 05, 2018 1:32 am
Thanks Sakaki, I did find that media-gfx/blender, not sure what it was.
I don't really want Blender, it has a demented UI :twisted:
But we know .Blender 2.78 does work in Raspbian.
I am trying to compile b4a, Blender with an easy to use UI ;)
https://www.bforartists.de/
The build dependencies did not build on latest 1.0 version but I suspect that is because it is using OpenCL.
I will try older versions tonight, all the compile tools seem to be working.
I suspect it is just lib make issues for ARMv7 and ARMv8.
Version 1.0 compiled fine on my Linux Mint box, but I noticed lots of things that I am sure might not(or ever) work on Pi.
I might be able to disable features, all I am after is the basic 3D obj and UV maker.
Gavinmc42
Thu Jul 05, 2018 11:40 am
Sakaki, nearly got Bforartists usable.
No images on the icons, build deps issue I think.
It jitters a bit but I think that is an OpenGL issue.
Making mesa3d demo windows bigger makes them jitter too.
I used "make lite" instead of the default "make" :D
sakaki
Thu Jul 05, 2018 12:40 pm
Looks good, can you write an ebuild for it (b4a) and then file it as a PR on the rpi3-overlay?
Best, sakaki
Gavinmc42
Thu Jul 05, 2018 2:37 pm
Hi Sakaki, need to fix some dependencies. I think OpenColor?
Or maybe just some path issues, it could even be no make for aarch64 issues.
I did get just get it to compile on Raspbian with the icon images :D
I have no idea how to do ebuilds or PR?
Not sure how to fix it but it was relatively painless to get it work.
If you can figure it out if would be a nice standard feature for Gentoo64, perhaps 1.23?
There are some of Eric's OpenGL driver fixes coming down line that might help.
I needed something to stress test Gentoo64's mesa3d.
Blender does that but it is a pain to use, b4a solves that.
Apparently there is a game engine built in too, not sure what comes with the 140MB lite version.
Gavinmc42
Fri Jul 06, 2018 2:15 am
Thanks for the ebuild guide links, it was on my list to find them one day.
This b4a/Blender does stuff I did not expect, it basically installs a build system where you can make new versions of Blender at anytime.
This makes it extremely hack-able and this seems to be part of it's attraction with users.
It makes the Lite version now, apart from the icons which looks to be just a path issue.
The default version has more deps and full version may never work on Pi's due to the GPU.
It also seems to be distribution independent, compiles on Debian, Raspbian and Gentoo, probably Windows too ;)
Lite also works better in Gentoo64 than Raspbian :D
I suspect this is due to it being 64bit optimized?
Not a cmake expert, but does cmake allow cross compiling?
Built target all aarch64?
Rebuild, rats still no icon images, might have do serious learning ;)
Gavinmc42
Fri Jul 20, 2018 12:11 pm
Ok BforArtists version 0.95 compiled with icons, using "make lite".
Very serious OpenGL testing setup :lol:
Time to learn how to make Blender games and models.
Gavinmc42
Mon Jan 21, 2019 3:05 am
Minetest will build.
Minecraft server as well, see another post
Going through the ebuild dev-games/ list there are a lot of useful stuff for making games etc.
Many games don't have Aarch64 ebuilds and expect x86 etc but a few do, it takes time to test which build easy.
One big one is Openscenegraph - it builds too, just expect it to take a very long time.
Because it is a library most stuff ends up in /usr/include
Still having compiler path issues so cannot compile and show demo yet :(
This would be useful for anyone doing 3D stuff like GIS.
Will the end results be fast enough on a Pi3B+, well that is the point, finding out?
The biggest of them all is Orge, will that build?
Gavinmc42
Mon Feb 18, 2019 10:53 am
Was looking for SVG to OpenVG source code and found Flightgear.
The prerequisites was interesting as Open Scene Graph did compile just before my SD card cooked itself.
http://home.flightgear.org/download/source-code/
Wonder if ....
Anyway the SVG to OpenVG is what I was after, RPI based flight instruments are possible.
Pi's as flight sim instrument displays are doable.
Gavinmc42
Sat Sep 07, 2019 10:33 am
Warzone2100 is still better in Gentoo64 than the Buster version :D
But there are others that work in Raspbian Buster with a 2GB Pi4 are 0AD and Flightgear.
These two did require a Pi with more than 1GB of ram.
Time to go read that Gentoo ebuild stuff.
And all the other stuff Sakaki has linked but did not make sense to me at the time.
I think the trick for using Gentoo64 on Pi's is going to be to have another Pi4 ebuilding.
Or a Pi4B4 compiling in the background?
So much stuff now works on Pi4.
Flightgear needs maps and TerraGUI is way of making scenery from real life GIS data.
Turns out Grass GIS and QGIS just apt-get install on Buster.
Those are serious Desktop Applications for a whole new field of science I am not up to speed on yet.
With Gentoo Aarch64 now a supported Gentoo version, how to get all this great and serious use apps built and out there on Pi4's.
Desktop GIS is a useful tool for Citizen Scientists, to be able to do it on Pi4's is a GIS price breakthrough.
Gavinmc42
Tue Dec 17, 2019 4:32 am
Hi Sakaki,
Eben and co have written a gaming book.
https://wireframe.raspberrypi.org/books ... -classics1
It uses Python and some Python libs.
import pgzero, pgzrun, pygame
Error at 1st import - pgzero
I cannot find any Gentoo info about pgzero or pgzrun.
It is supposed to be abstraction layers over pygame?
Pygame already works in Gentoo64
How to ebuild python libs like these?
sakaki
Wed Dec 18, 2019 1:44 pm
Never tried this, but try installing (per these notes) via pip? You can use a virtual environment to stop this package 'polluting' your vanilla Gentoo Python setup.
Assuming the pip route works, it would be relatively straightforward to create an ebuild for this package (see e.g. any of the dev-python/pygame ebuilds for an example of the sort of framework required).
hth, sakaki
Gavinmc42
Thu Dec 19, 2019 4:00 am
Pip did not work, that's why I asked.
There does not seem to be pgzero in Gentoo for pip to find.
My question should have been how to make/put one in Gentoo so it can find and build it.
I have found some pgzero source on github so will have a play with that this weekend.
It seems pgzero has been around for years on Debian but not in Gentoo?
Wiki page on how to port debian libs to gentoo libs?
Gavinmc42
Fri Dec 20, 2019 10:34 am
https://github.com/lordmauve/pgzero
sudo python setup.py install
worked fine. :D
Not sure how that can be turned into an ebuild.
Anyway, I am still crap at the bunny version of Frogger :oops:
64bit gaming, yippee :D
Now if only I had a 64 bit version of BBC Basic and Laz/FPC.
Going to be interesting to see if Python GLSL Shader code will play nice with Pgzero.
Looking like it will be a fun xmas break.
Networked accelerated Python gaming, so need to try this on my Pi3's.
Return to “Gentoo”
