sidsst wrote: ↑Mon Jun 18, 2018 11:12 am
In my case both my Pi and my android phone will be connected to a single wifi. I want to communicate between the two devices over this wifi. If you are talking about pi being an AP standalone server , I unfortunately do not need that. If it is something else , could you please suggest me how to do it. Thanks. Been stuck on it for 2 months now
My set-up is Android to WiFi router, PC to WiFi router, that could be Pi to WiFi router. No AP except for that router itself acting as one.
If you can access your Pi when it's an AP, it should be just the same to access it when the Pi is connected to a WiFi router. The Pi might get a different IP address and you would have to change that on the Android App but that should be all you need to do.
It should 'just work', everything connected to the WiFi router should be on the same network, the local LAN, though you might have to tweak the router settings to allow it to work.
Perhaps describe what you have done, what doesn't work, what errors messages or problems you are getting.
