This subject has been discussed several times but all the solutions I found don't work for me.
Most of them are for Wheezy or Jessie. I'm using latest Raspbian version Stretch and I think ALSA is not exactly the same.
I'm using this speaker and this microphone.
I can record using this command
arecord -D hw:1,0 --format S16_LE --rate 44100 -c1 default.wav -vv
but I want to use the command without specifying the device (and use the default one).
arecord --format S16_LE --rate 44100 -c1 default.wav -vv
I don't have an error when executing this command, but it gives me an empty file.
I don't need to specify the device when using aplay. It plays directly on the speaker.
The speaker needs a specific /etc/asound.conf configuration.
pcm.!default {
type plug
slave.pcm "softvol_and_pivumeter"
ctl.!default {
type hw
card 0
pcm.pivumeter {
type meter
slave.pcm "hw:0,0"
scopes.0 pivumeter
pcm.softvol_and_pivumeter {
type softvol
slave.pcm "pivumeter"
control {
name "PCM"
card 0
pcm_scope.pivumeter {
type pivumeter
decay_ms 500
peak_ms 400
brightness 128
output_device speaker-phat
pcm_scope_type.pivumeter {
lib /usr/local/lib/libpivumeter.so
pcm.dsp0 pivumeter
Latest version /etc/asound.conf looks like this:
pcm.usb {
type hw
card 1
pcm.!default {
type asym
playback.pcm {
type plug
capture.pcm {
type plug
slave.pcm "usb"
ctl.!default {
type hw
card 0
pcm.pivumeter {
type meter
slave.pcm "hw:0,0"
scopes.0 pivumeter
type softvol
control {
name "PCM"
card 0
type pivumeter
decay_ms 500
peak_ms 400
brightness 128
pcm.dsp0 pivumeter
**boot/config.txt**
#dtparam=audio=on # disable Build-in audio
start_x=1
gpu_mem=256
dtoverlay=i2s-mmap # for Speaker pHat
dtoverlay=hifiberry-dac # for Speaker pHat
[email protected]:~ $ arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
usb
default
Playback/recording through the PulseAudio sound server
pivumeter
sysdefault:CARD=Device
USB PnP Sound Device, USB Audio
Default Audio Device
front:CARD=Device,DEV=0
Front speakers
surround21:CARD=Device,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Device,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Device,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Device,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Device,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Device,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Device,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Device,DEV=0
Direct sample mixing device
dsnoop:CARD=Device,DEV=0
Direct sample snooping device
hw:CARD=Device,DEV=0
Direct hardware device without any conversions
plughw:CARD=Device,DEV=0
Hardware device with all software conversions
[email protected]:~ $ cat /proc/asound/modules
0 snd_soc_hifiberry_dac
1 snd_usb_audio
