lebi
VPN on Pi - problem with creating ovpn files
Thu Jun 14, 2018 11:26 pm
first time I did this but following instruction on this page. everything went ok. when I get to a point I'm creating the client file I'm getting this
 cp: cannot create regular file `/home//ovpns/pivpn-client1.ovpn': No such file or directory
chown: cannot access `/home//ovpns/pivpn-client1.ovpn': No such file or directory
and after that it states that it was created but in a path ->> /home//ovpns:
Done! pivpn-client1.ovpn successfully created!
pivpn-client1.ovpn was copied to:
  /home//ovpns
for easy transfer. Please use this profile only on one
device and create additional profiles for other devices.
Firstly I don't understand why the path has "/" and then "//" -> that doesn't make sense for me. Secondly when I looked into file system there is no such directory as well as the file with *.ovpn extension anywhere on my disk.
Any ideas how can I get this working please?
Below the whole code when I want to add a client:
[email protected] ~ $ sudo pivpn add
cat: /etc/pivpn/INSTALL_USER: No such file or directory
Enter a Name for the Client:  pivpn-client1
Enter the password for the client:
Enter the password again to verify:
spawn ./easyrsa build-client-full pivpn-client1
Note: using Easy-RSA configuration from: ./vars
Generating a 2048 bit RSA private key
writing new private key to '/etc/openvpn/easy-rsa/pki/private/pivpn-client1.key.B9r8jyAW88'
Enter PEM pass phrase: mojehaslo
Verifying - Enter PEM pass phrase: mojehaslo
Using configuration from /etc/openvpn/easy-rsa/openssl-1.0.cnf
Check that the request matches the signature
Signature ok
The Subject's Distinguished Name is as follows
commonName            :PRINTABLE:'pivpn-client1'
Certificate is to be certified until Jun 11 22:32:18 2028 GMT (3650 days)
Write out database with 1 new entries
Data Base Updated
spawn openssl rsa -in pki/private/pivpn-client1.key -aes128 -out pki/private/pivpn-client1.key
Enter pass phrase for pki/private/pivpn-client1.key: mojehaslo
writing RSA key
Verifying - Enter PEM pass phrase:mojehaslo
Client's cert found: pivpn-client1.crt
Client's Private Key found: pivpn-client1.key
CA public Key found: ca.crt
tls-auth Private Key found: ta.key
cat: Default.txt: No such file or directory
  /home//ovpns
epoch1970
Re: VPN on Pi - problem with creating ovpn files
Fri Jun 15, 2018 10:28 am
You probably installed incorrectly.
The script is missing the user name. It wasn't saved in /etc/pivpn/INSTALL_USER and it's missing throughout: paths like "/home//ovpns" should look like "/home/pi/ovpns".
I would remove /etc/pivpn and try reinstalling the script from scratch.
It could be a bug in that script, though. There is a github page I suppose you can contact the authors there.
lebi
Fri Jun 15, 2018 10:13 pm
that's what I did. raised an issue with them but thought it's possible to somehow edit a config file or something to overcome this. unfortunately I'm not fluent in linux so still need a step by step guide for such things.
