lecause
Force Internet traffic through wlan0
Thu Jun 14, 2018 2:51 pm
I currently have a setup where my rpi 3b (raspbian jessie), is connected to two routers, using eth0 and wlan0. I want to using eth0 only to communicate with another device in tha LAN. And i want to use wlan0 for WAN traffic via the router.
How can i ensure that only the network on wlan0 is used for internet traffic? this must require some action? I want to use the network on eth0 only for communicating with a device in the same LAN.
RPI eth0 -> router A -> Device in LAN. (RPI assigned dynamic IP in range 10.x.x.x)
RPI wlan0 -> router B -> any WAN traffic. (RPI assigned a static IP 192.168.1.13 via router settings)
I do not have admin access to router A. Also, the static ip address on wlan0 is set up on the router by MAC binding, menaing i did not change any network configurations on the pi.
i have tried using the ip route command which does momentarily work, however, all settigns go back as they were after a reboot or if the etherenet cable is uplugged and plugged back in.
What else can i do to achieve this? I need to do this on a rpi 3b runnign jessie and on a rpi 3b+ running stretch. Any help would be appreciated.
lmarmisa
Re: Force Internet traffic through wlan0
Thu Jun 14, 2018 5:27 pm
Try assigning metrics to interfaces wlan0 and eth0. A lower metric means a higher priority.
Yo have to edit the file /etc/dhcpcd.conf
sudo nano /etc/dhcpcd.conf
and the add these four lines:
interface wlan0
metric 10
interface eth0
metric 50
Check the metrics after reboot:
ip route
Return to “Advanced users”
Who is online
Users browsing this forum: Google [Bot], Neil_G and 10 guests
